Belly Pans - Page 3 - Steve Saunders Goldwing Forums
 18Likes
post #21 of 26 (permalink) Old 10-10-2018, 09:51 AM
CWN
CWN's Avatar
Year: Pro 1500
Model: 43 years winging it
Buddy ran over a piece of metal on his 1100 in Colorado that cracked one side of the case and after 1,300 mile uhaul tow back to calif, he calls me @ get over here and fix it for me.
After I tore it down, a chapter member welded it up for him, then I buttoned it up with not one extra part laying around and it even ran, not bad for my first/last tear down in 1983 ~:<)
I jack the 1500 up on the belly pan...no problemo.
DaveO430 and CrystalPistol like this.
CWN is offline
post #22 of 26 (permalink) Old 10-10-2018, 12:39 PM
rayjoe's Avatar
I bet a fellow could build a nice one of 1/4" steel plate (or thicker) and jack under that, just use aluminum aftermarket as a pattern to start from?
Weight would lower a bike or trike's center of mass, maybe better handling, . like result when we added thick brass belly pans to our HO slot cars.
That would probably be overkill. One square foot of 1/4" steel weighs just over 10 pounds.
Rayjoe
CrystalPistol likes this.
rayjoe is offline
post #23 of 26 (permalink) Old 10-10-2018, 01:38 PM
pidjones's Avatar
Model: '06 GL1800, '78 GL1000 with '75 motor
I've had one for most of the ~113k miles on our '06. No overheating issues. Several dents from road hazards. One was a concrete chunk the flew at me from a car hitting the median in front of me. The others, I don't know. Full disclosure, I use Rotella T6, run flat car tire, and have an ancient GPS on the handlebar.
"Love 'em all... Let God sort 'em out!"
'52 wife - '69 daughter - '83 daughter
ex '86 SE-i
ex '77 GL1000
pidjones is offline
post #24 of 26 (permalink) Old 10-10-2018, 02:44 PM
CrystalPistol's Avatar
Rayjoe
2 squares should do it .. with sufficient brackets, say 25-30 lbs
.. and no doubt would set off traffic light sensors buried.
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
CrystalPistol is offline
post #25 of 26 (permalink) Old 10-10-2018, 05:49 PM
If the light don't trip, I just go when traffic clears.
NASR 12 in Galena, IL
post #26 of 26 (permalink) Old 10-31-2018, 04:45 PM
I do have a piece of 1/4" aluminum about 3x4 feet, some body's scrap.
Could have been bad, found matching parts that night on Ebay. The rivets are where some re-inforcement pieces are fastened inside. Frt tire flipped a flat rock up and it caught between trike & road. Even banged up muffler.
...( Vintage Red )
Hey! Who's the guy making GL1800 Belly Pans on the forum? AZgl1800 General Motorcycle Discussion Forum 4 01-24-2015 08:01 AM
Belly pans Wings of Fire General Motorcycle Discussion Forum 11 09-29-2014 11:44 PM
Belly pans for the 1500 flw General Motorcycle Discussion Forum 15 10-20-2010 10:22 AM
Belly pans - What holds 'em on - friction?? miles.from.nowhere Goldwing Technical Forum 10 04-30-2007 01:04 AM
Belly pans for 1800 Rich Steinel General Motorcycle Discussion Forum 9 09-18-2005 08:55 AM
