Weird noise - Steve Saunders Goldwing Forums
post #1 of 20 (permalink) Old 10-07-2018, 07:20 PM Thread Starter
Year: 1995
Model: GL1500 SE
Weird noise
When I'm doing 50 mph and pull the clutch in makes a weird noise and when I let off the throttle at 50 and above makes same noise but dissent do this below 45 any advice
Adrian.rainey513 is offline
post #2 of 20 (permalink) Old 10-07-2018, 07:34 PM
Is it possibly the speedo cable?
post #3 of 20 (permalink) Old 10-07-2018, 07:40 PM Thread Starter
Year: 1995
Model: GL1500 SE
When I'm giving it the gas it didn't do it only when I pull clutch in or let off the gas at 50 doe t do this at lower speed I will check Speedo cable thanx
post #4 of 20 (permalink) Old 10-07-2018, 07:43 PM
Seems like a drive train thing, then? Does it do it in any gear?
post #5 of 20 (permalink) Old 10-07-2018, 07:46 PM Thread Starter
Year: 1995
Model: GL1500 SE
4th and overdrive just started doing this today and only when I go over 45
post #6 of 20 (permalink) Old 10-07-2018, 07:59 PM
Well, drive train issues should be evident in any gear and pretty much any speed. So, my first guess would be tires. How's the pressure?
Others should be along soon with other opinions.
post #7 of 20 (permalink) Old 10-07-2018, 08:01 PM Thread Starter
Year: 1995
Model: GL1500 SE
Tire pressure is good
post #8 of 20 (permalink) Old 10-07-2018, 08:17 PM
Just one of the guys
DougW's Avatar
Could it be a front bearing making noise when the load changes from deceleration? Could also be the front tire if it is cupped just right.
Doug
DougW is online now
post #9 of 20 (permalink) Old 10-08-2018, 09:09 PM
Guru
Hatchetman's Avatar
When your on the throttle there is a constant load on your drive line. Pulling in the clutch takes the load off & allows the parts of the drive line to float & the joints get some free play. 5th gear & over 50 suggests that 5th gear might have some play that might be excessive. If this is not the case, how long has it been sense you had the rear tire off for replacement? When it was off were the drive gears coated with Molly 50 paste as a lubricant? When you put the bike on the center stand, get the rear wheel up off the ground & double check it for excessive play side to side just for safety.
AZgl1800 likes this.
Hatchetman is offline
post #10 of 20 (permalink) Old 10-08-2018, 09:39 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
On the 1000 and 1100 the drive shaft needs to be pulled every few years and the splines greased at both ends. As Hatchet says, the splines on the wheel should be cleaned and greased. The correct grease for the 1100 is Moly 60. When I took my 1100 apart the drive shaft rear spline was nearly worn through. I have heard stories of the splines completely failing and the dirve disconnecting the engine from the wheel. The 1200 FSM says Moly 50, I doubt is there is much difference. If the local Honda motorcycle shop doesn't have it, try Honda Marine.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
Weird noise while driving Transcanada Goldwing Technical Forum 22 05-25-2010 06:46 AM
Hard Shifting weird noise schpeener General Motorcycle Discussion Forum 2 04-11-2010 04:14 AM
Noise, noise noise in my GL1100 headset. rb7632 Goldwing Technical Forum 11 10-10-2009 04:42 PM
Weird Noise 1984GL1200TX Goldwing Technical Forum 21 12-09-2008 08:13 PM
1999 1500 Aspencade weird noise Luke the Drifter Goldwing Technical Forum 12 11-21-2008 08:40 AM
