Air Shock's 1990 GL1500 - Steve Saunders Goldwing Forums
  • 1 Post By DBohrer
post #1 of 5 (permalink) Old 10-29-2018, 08:03 PM Thread Starter
McFirefighter's Avatar
Year: 1990
Model: Aspencade
Send a message via MSN to McFirefighter Send a message via Yahoo to McFirefighter Send a message via Skype™ to McFirefighter
I have a 1990 GL 1500 I was told that my bike only has one Air Ride shock on the right rear, can anyone tell me
if this is true?. And if so why I have not check to see if it has one on the left side. Thanks MCFF
Patriot Guard Rider #144639
McFirefighter is offline
post #2 of 5 (permalink) Old 10-29-2018, 08:54 PM
haroldaugustine's Avatar
Model: 1995 Gl1500se
Well, my 1995se had the oem shocks which was 1 air ride, 1 normal shock. that was the oem configuration. I have changed to Progressive 416 dual air shocks for a (my opinion only) bettter ride with 2 up and just me. they work well with my Progressive front fork springs, no more dive on braking.
“Those who surrender freedom for security will not have, nor do they deserve, either one.”
1995 Honda Goldwing GL1500se
haroldaugustine is offline
post #3 of 5 (permalink) Old 10-29-2018, 08:57 PM
The seat is simple to remove to check for your self. 4 allen bolts and viola. while you are there may as well check and clean any electrical connections there (just a thought)
post #4 of 5 (permalink) Old 10-30-2018, 04:49 AM
Year: 1992
Model: Aspencade 1500
One air shock on the right with oil inside, but not a full damper. On the left is a spring shock with a full damper.
My guess is that is a reliability compromise. Even if you blow an air line you will still have the spring side to get you home.
I used to have a CB750 with dual airshocks, and no springs. More than once I found them empty in the morning and had to limp to a gas station to fill them to go to work. Hardtail Honda is no fun.
You can change the oil in your airshock and the protective rubber boot has probably gone bad and can be replaced.
RambozoClown is offline
post #5 of 5 (permalink) Old 10-30-2018, 11:24 AM
DBohrer's Avatar
Model: '99 Gold Wing SE
if this is true?
That is true for the OEM rear suspension.
CrystalPistol likes this.
DBohrer is offline
GL1500 torn shock boot....stock air shock SmartBiker Goldwing Technical Forum 4 08-25-2011 07:41 AM
1990 SE Rear Air Shock problems charz Goldwing Technical Forum 5 07-08-2011 12:28 PM
GL1500 shock air pressure and air pressure for tires? Scott Wheeler Goldwing Technical Forum 13 11-01-2010 07:24 AM
1990 GL1500 air shock shakyone Goldwing Technical Forum 2 10-18-2010 04:24 PM
GL1500 non air shock forks to air forks? skoto1 Goldwing Technical Forum 5 10-01-2010 04:22 PM
