hyper flashing - Steve Saunders Goldwing Forums
  • 1 Post By Bike...and Dennis
post #1 of 7 (permalink) Old 11-01-2018, 08:57 PM Thread Starter
Year: 2003
Make: honda
Model: gl1800 Trike
hyper flashing
just installed LED'd on my 03 GL1800 trike getting some hyper flashing on directionals .what's the easiest fix ?the hyper flashing isn't that bad ,just faster than normal
genman is offline
post #2 of 7 (permalink) Old 11-01-2018, 10:00 PM
Probably because the LEDs don't pull enough current to make the flasher element to get hot enough to have the proper rate.
never worked on that circuit, but I'm thinking you need to replace the Flasher itself with an Electronic Flasher that does not care how much, or little current is on the load...
Remember how the older cars were when one bulb burns out? they flash real fast.
post #3 of 7 (permalink) Old 11-01-2018, 10:18 PM
The quickest and best fix is to use the correct bulbs. They're probably brighter than the LEDs too.
DaveO430 likes this.
post #4 of 7 (permalink) Old 11-01-2018, 10:21 PM
Pastot's Avatar
It's a pain to get to but you can replace the flasher circuit in the dash display with a digital for about $10 and some wire. Their is s 3 wire plug accessible under the windscreen and it's fairing piece. You'll need to wire the flasher unit into the 3 wire plug. I think I added a pic to my profile media/photos. Over heard the wire can be reached from the underside in the form tunnel but I didn't try that with my big hands.
Sent from my Moto Z (2) using Tapatalk
Tom, in Mountain Home, Idaho
2002 GL1800 (Illusion Red) Non-ABS, 128k miles
Retired Air Force
"Audentes Fortuna Juvat"
Pastot is offline
post #5 of 7 (permalink) Old 11-02-2018, 06:54 AM Thread Starter
Year: 2003
Make: honda
Model: gl1800 Trike
thanks,I was thinkin the same
genman is offline
post #6 of 7 (permalink) Old 11-02-2018, 06:56 AM Thread Starter
Year: 2003
Make: honda
Model: gl1800 Trike
you might be right ,I didn't notice much difference in brightness
genman is offline
post #7 of 7 (permalink) Old 11-02-2018, 06:58 AM Thread Starter
Year: 2003
Make: honda
Model: gl1800 Trike
thanks for the reply
genman is offline
Hyper-Lites Bluewaterhooker0 General Motorcycle Discussion Forum 6 12-25-2015 11:44 PM
Hyper-Lites jaxn General Motorcycle Discussion Forum 5 08-07-2014 07:51 AM
Hyper pro GL1800 meison Goldwing Technical Forum 7 01-29-2011 03:48 AM
Hyper-Lights Roryrob General Motorcycle Discussion Forum 2 07-02-2009 02:44 PM
'hyper' turn signal jedinice1980 Goldwing Technical Forum 14 06-21-2005 04:57 PM
