Neat centre stand trick. - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 16 (permalink) Old 11-09-2018, 04:13 PM
Bill-UK's Avatar
Model: Gl1500 SE
This should be an option
AZgl1800 likes this.
Bill-UK is online now
post #12 of 16 (permalink) Old 11-11-2018, 11:15 AM
Peter Goldwing's Avatar
Year: 2008
Model: GL 1800
Maybe he should add 2 more wheels , A/C, roof, steering wheel and call it a car.
If you keep your training wheels on you'll rely on them and never become confident in slow turns or handling the bike at slow speeds.
Regarding the center stand, I only use it for maintenance and I don't miss anything else.
But to each his own.
Follow me on the spot
Peter Goldwing is offline
post #13 of 16 (permalink) Old 11-11-2018, 11:23 AM Thread Starter
Hodgy's Avatar
Model: 97' SE, Two Tone Red --> 124,024 km as of November 2015
I'm thinking its for the end of your Goldwing riding lifespan not the beginning.
Bike...and Dennis likes this.
Avatar Photo was taken in the Crowsnest Pass between Alberta and British Columbia on Highway 3.
Hodgy is offline
post #14 of 16 (permalink) Old 11-14-2018, 04:06 PM
joe in calif's Avatar
I had one o my 92 Wing. As Bill in UK said, both wheels are on the ground so either leave it in reverse or put it in gear other wise you will find it on the ground.
A NEW START ON 1/20/2017
joe in calif is offline
post #15 of 16 (permalink) Old 11-15-2018, 06:12 PM
Year: 1987
Model: GL1200 Interstate
First time I witnessed that 'trick' was 1976 at a Honda dealer where I was buying my first new road bike...1976 Honda 550-4 SuperSport. The mechanic did it while moving my bike out to the lot. The rear wheel on the '76 was off the ground so just give it throttle, let go of the clutch and rock the bike rearward. No special equipment needed, geez.
BadMonk's1200 is offline
post #16 of 16 (permalink) Old 11-16-2018, 10:19 AM
After I put one on my 92 I went to the Honda shop for something. When I got there 2 mechanics were siting outside on their lunch brake, I put the bike in reverse and rode up on the stand, you should have seen the look om their faces, they never knew about a ride off stand, and I don't think I ever told them either.
Back in the mid 90's we went to Marysville Ohio and toured the Honda plant. Those guys who rode the wings off the dyno at the end of the assembly line rode them to staging area and did ride them up on the center stand, that was a sight to see.
Neat trick for keeping plastic browner_77 General Motorcycle Discussion Forum 4 01-03-2017 09:25 PM
Neat Trick - Drone lands on moving platform AZgl1800 Miscellaneous Forum 0 01-26-2016 12:16 PM
stumbled on a neat trick today... UbarW Miscellaneous Forum 20 08-08-2012 10:32 PM
Side stand or centre stand Harry Goldwing Technical Forum 3 05-26-2009 10:19 AM
Stumbled onto a neat cold weather riding trick for a 1500 AZgl1800 General Motorcycle Discussion Forum 5 02-11-2007 08:58 AM
