Gas dripping out of tube under bike - Steve Saunders Goldwing Forums
 2Likes
  • 2 Post By Bike...and Dennis
post #1 of 7 (permalink) Old 12-16-2018, 10:41 PM Thread Starter
Year: 1990
Make: GL1500
Model: Aspencade
Hi Folks;
I bought my friend's 1996 GL1500 with appx 36,000 miles on it. I also have a 1990 GL1500 with 78,000 miles. When I drive the '96, there is gas dripping out of one of the tubes that sticks out of the bottom near the engine. My '90 has never done this.
What is this telling me? My buddy said the local HD dealer had cleaned and adjusted the carb but I am wondering if the shop did something wrong. The cycle hasn't been run much in the past 3 years due to his health. Do I need to run some carb cleaner through it or are some more drastic measures in order? I just got the bike and haven't had a chance to inventory the maintenance that needs to be done to it.
I also noted the exhaust is louder on the 96 compared to the 90? Should they sound the same or ass the '96 designed to be 'throatier"? I'll get some pictures and post them in the next few days.
Dave in Pierre, SD
dvoeltz is offline
post #2 of 7 (permalink) Old 12-17-2018, 12:34 AM
You need to take it to a motorcycle mechanic. (Not an HD guy)
My guess is you have a float that doesn't anymore or is badly out of adjustment. Those are overflow tubes under the bike.
JamesPal and Peter Goldwing like this.
post #3 of 7 (permalink) Old 12-17-2018, 06:03 AM
My thought exactly. You have a carb(s) overflowing which will have to be dealt with by someone who knows what they are doing. And someone, maybe the same hardly guy, probably modified the exhaust.
post #4 of 7 (permalink) Old 12-17-2018, 08:54 PM
Year: 1985
Model: Aspencade
It's possible that the float stuck to the bottom if it sat with gas in it and the gas evaporated. (This can happen in a few days in Texas)
I started leaving the petcock open on my 1200 to keep gas in the bowl so the float would not stick.
If float is stuck it should unstick after soaking in new gas for a day or two. If it doesn't unstick, you are in for a carb disassembly and cleaning (or worse as Bike and Dennis mentioned).
Spending more time on my wife's hobby than the wing.
Wes Scott is offline
post #5 of 7 (permalink) Old 12-17-2018, 10:21 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
It is a good thing it is flowing out of the overflow tube. If that gets plugged up the gas winds up in the cylinder for hydrolock or dilutes the oil in the bottom end.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #6 of 7 (permalink) Old 12-17-2018, 10:46 PM
Would be helpful to always park it on the Center Stand....
post #7 of 7 (permalink) Old 12-17-2018, 11:23 PM
dadztoy's Avatar
Year: 2009
Model: 2009 Silver GL1800 ABS
Probably a stuck float but check the easy things first - make sure the carburetor drain screws are tight...
4 wheels moves the body
2 wheels moves the soul
GL1800 HPNAM9
Double Darkside - BT-45
dadztoy is online now
Gas dripping out the tubes under the bike kstrauss Goldwing Technical Forum 22 12-23-2015 01:19 AM
GL1200 dripping gas iccats Goldwing Technical Forum 9 08-12-2011 07:02 AM
gas dripping from exhaust Jaws Goldwing Technical Forum 12 06-13-2008 07:13 AM
Oil Dripping out Water Pump Weep Hole, Which Seal? zowie Goldwing Technical Forum 5 05-08-2007 10:48 AM
Water Dripping out of Exhaust phatty Goldwing Technical Forum 9 06-26-2006 05:58 PM
