i have buyers remorse - Page 5 - Steve Saunders Goldwing Forums
 23Likes
post #41 of 65 (permalink) Old 03-27-2019, 05:42 PM
bobalou's Avatar
Year: 1981
Model: 1100
Originally Posted by Wingman11! View Post
question other than randakks carb kit. what kit would you suggest for ME. i plan
on reusing the brass parts and leaving carbs attached to plentum. kinda just a o-ring kit???
contact pistol Pete.
They are all perfect
Last samuri
bobalou is offline
post #42 of 65 (permalink) Old 04-27-2019, 03:08 PM Thread Starter
Year: 82
Make: gl1100
Model: interstate
bobaloo took your advice and had pistol pete rebuild the carbs.
found broken return cable now having trouble getting em hooked
up on the carb?? any pictures??
Wingman11! is offline
post #43 of 65 (permalink) Old 04-27-2019, 03:11 PM Thread Starter
Year: 82
Make: gl1100
Model: interstate
also cleaning gas tank..
post #44 of 65 (permalink) Old 04-27-2019, 08:55 PM Thread Starter
Year: 82
Make: gl1100
Model: interstate
got it. it was the throttle lock..
post #45 of 65 (permalink) Old 05-02-2019, 11:10 PM Thread Starter
Year: 82
Make: gl1100
Model: interstate
ok got a lot put back together. i was going to flush out the fuel pump
but i can not get gas to flow out the pump??? any help??? or ideas??
pet **** open new filter on the right way, gas in filter but not pumping
through???
post #46 of 65 (permalink) Old 05-02-2019, 11:52 PM
Year: 1992
Model: Aspencade 1500
Maybe I'm doing something wrong, but I've never had to use a chainsaw to work on my bike.
RambozoClown is offline
post #47 of 65 (permalink) Old 05-03-2019, 05:25 AM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
I think you beginning to see value in what you've invested , as you have posted a sentry to keep guard
You might want to use a small container of gasoline to at least get the bike running . Just fix it up on gravity feed . If the bike starts up then the mechanical pump may begin to work , so be sure to put its outgoing line into a catch container.
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #48 of 65 (permalink) Old 05-03-2019, 06:15 AM
[IMG]
through???
The check valves in the pump may be stuck. A little pressure may pop them loose.
post #49 of 65 (permalink) Old 05-03-2019, 08:29 AM
rayjoe's Avatar
Where do you think choppers come from?
Rayjoe
rayjoe is offline
post #50 of 65 (permalink) Old 05-03-2019, 07:01 PM Thread Starter
Year: 82
Make: gl1100
Model: interstate
thanks guys. hooked it up to over head gas. started right up.
i should thank pistol pete. ran it sever minnutes tapping on
fuel pump many times nothing?? looks like i need a new fuel pump.
Remorse, Regrets and Expectations Dubswing General Motorcycle Discussion Forum 37 11-08-2011 03:36 PM
Buyers Club morram General Motorcycle Discussion Forum 34 06-20-2010 08:59 AM
buyers guide steve green Goldwing Technical Forum 2 03-15-2008 12:27 PM
Ebay Buyers Beware RonSena General Motorcycle Discussion Forum 13 02-17-2008 04:55 PM
2006 buyers guide in motorcyclist mag UbarW General Motorcycle Discussion Forum 1 03-12-2006 06:39 AM
