tire change - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 05-12-2019, 03:07 PM Thread Starter
fireshine's Avatar
Year: 2012
Model: 2012 1800 nav/xm
tire change
cold rainy day here in upstate NY so thought i would change my tires on the wing, got it on the lift got the 5 tools out to remove the front wheel, first the right caliper check pads, good the left caliper check pads, not so good, yep need brakes change about 30k ago with oem guess i'll install oem back on. question on the Michelin, which way ? if i keep the sips the way they are on the front tire now, i would have to reverse the tire.
sanity,
2014 roll a home wide
2017 africa twin
fireshine is offline
post #2 of 9 (permalink) Old 05-12-2019, 03:16 PM
I thought you already asked that question.
post #3 of 9 (permalink) Old 05-12-2019, 05:48 PM Thread Starter
fireshine's Avatar
Year: 2012
just making sure ! i know how i am mounting it just like to know what others think
sanity,
2017 africa twin
post #4 of 9 (permalink) Old 05-12-2019, 06:16 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
If you have already decided how you are mounting it, then why want other opinions...??
DBohrer is offline
post #5 of 9 (permalink) Old 05-12-2019, 06:19 PM Thread Starter
fireshine's Avatar
Year: 2012
Maybe someone has mounted this tire both ways at one time and one way was better then the other but usually one mounts one way and another mounts another way
sanity,
2017 africa twin
post #6 of 9 (permalink) Old 05-12-2019, 06:25 PM Thread Starter
fireshine's Avatar
Year: 2012
Just like the brake pads I’m getting I like the ones I use but I have looked at others to see what others think, I like oem’s but I was thinking of getting the sintered pads ordered the oem’s but curious on what others think of the sintered ones , info man info I gather so much info on things some times I do change my mind because a lot of people have tried them and let others know about it. Like reviews.
sanity,
2017 africa twin
post #7 of 9 (permalink) Old 05-12-2019, 06:38 PM
Yes I have, said so in your other thread. Doesn't seem to matter, it cups in either direction.
post #8 of 9 (permalink) Old 05-12-2019, 06:45 PM Thread Starter
fireshine's Avatar
Year: 2012
How was it in the rain and standing water on the road? I ran the bt45 backwards no issues in the heavy rain
sanity,
2017 africa twin
post #9 of 9 (permalink) Old 05-12-2019, 09:54 PM
Seemed to be fine with water either direction.
Title Change Testing Change 2 sandiegobrass Test Forum 1 10-16-2012 05:19 PM
The Book Says Don't Change the Oil(first change) til 4,000 miles instead of 600miles? gixxerbill Goldwing Technical Forum 3 06-25-2007 04:06 AM
Rear tire change UbarW Goldwing Technical Forum 3 08-24-2005 04:36 AM
Front tire change... UbarW Goldwing Technical Forum 6 05-25-2005 02:02 AM
