-   General Motorcycle Discussion Forum (https://www.goldwingfacts.com/forums/5-general-motorcycle-discussion-forum/)
-   -   2002 gl1800 towing package suggestions? (https://www.goldwingfacts.com/forums/5-general-motorcycle-discussion-forum/668297-2002-gl1800-towing-package-suggestions.html)
weatherly1957 07-26-2019 03:50 AM
I just bought a 2002 gl1800. I had been riding a 95 gl1500, but the transmission blew up on it and I decided to move up to the 1800. My wife and I have a tent trailer that we towed on the 95, but my new bike doesn’t have a hitch. Can anybody suggest a good one to buy that won’t break the bank, and is hopefully relatively easy to install?
Thanks!
AZgl1800 07-26-2019 04:20 AM
make sure it is the solid steel frame members that bolt clear up to the seat/trunk.
Mine looks like an 'H' frame, has the vertical receiver.
Nothing about it is wimpy, dunno the brand, it was there when I bought the bike.
it is solid as a rock, the trailer becomes "invisible" behind me as to "feeling it".
have to look in the mirrors to be sure it is still there.
pulled it thru the tightest twisties without even feeling that it is there.
can't find my pictures of it right now, on a new laptop.
DaveO430 07-26-2019 05:57 AM
This is a case where the cheapest option is the best option IMO. https://cyclemax.com/inc/sdetail/gl1...r_hitch/76/703 Easier to install and as strong as it needs to be.
joe in calif 07-26-2019 10:00 AM
Before you start putting any more stress on that 02 make sure the frame recall and the over heating issue has been completed
AZgl1800 07-26-2019 10:10 AM
mine is an '02 and never been a problem.
at this point in time, all of the "problems" that would show up with the Gen 1 bikes would have already shown up.
DBohrer 07-26-2019 07:57 PM
We have installed a couple of the "Add-ON" hitches on GL1800's.....!!
Pastot 07-26-2019 11:41 PM
I have an Add-On hitch also and have had no issue with probably 20k miles trailering. I've hauled as much as 550 lbs and no problems. This hitch has 6 connection points, uses a vertical receiver so you needn't cut any tupperware. While you're at this you'll probably need a 5 to 4 wire converter for your trailer, assuming it's a flat four connection. Most would also advise a trailer isolator. With a bit of planning you could have both a 4 and 5 wire trailer connections for flexibility. I also added a connection for an electric cooler power through a relay triggered of the auxiliary power so it shuts off with the key to save your battery. Probably 3 hours work and your done.
Sent from my Moto Z (2) using Tapatalk
DenverWinger 07-27-2019 05:44 AM
+1 on the Trailer Isolator, -1 on the 5-to-4 converters.
The Isolator saves putting extra load on your turnsignal / brake / running light circuits, it's a little relay bank that's triggered by the lighting circuits but sends power direct from the battery to your trailer lights instead of loading the circuits directly. Cyclemax has them, they are plug-and-play install.
https://www.cyclemax.com/inc/sdetail...ess/120/418532
My experience with 5-4 wire converters is less than stellar, while they DO work, the internal voltage drops in combining the brake and turnsignal lines resulted in brake/turn light on the trailer that wasn't that much brighter than the running light. I figure visibility on the bike to be of paramount importance so I ditched the converter, and added separate bright amber turnsignal fixtures to the trailer on a separate plug, leaving the original 4 wire plug intact so I can still use the trailer on my Jeep which has only 4 wire plug. So two plugs to connect trailer to bike, only use the 4 wire plug on the Jeep. Works perfect.
joe in calif 07-27-2019 09:02 AM
If the bike is low miles the frame cracks might not have shown up yet. I agree that most owners of the early wings have had the recalls completed but there are still out there that have not had it completed.
Here are a few places that cracks have appeared, some are not covered under Honda re weld program
There are other areas that are known to crack on pre 05 models.
Here is a picture of where to look. The most common is right behind the passenger footrest. You will have to remove the passenger floor board and silver cover. You may also be able to see it from underneath the bike.
https://goldwingdocs.com/forum/downl...b90e63db888097
flylow 07-27-2019 09:29 AM
True, the isolator will reduce electrical loads on the bike circuits. However, I feel the best reason to use one is to protect the bike wiring. If the trailer develops a short circuit then the fuse (located close to the battery) for the isolator circuit will protect the trailer and isolator wires. If this fuse opens, you will still have all the bike's normal lighting intact.
