ride height - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 19 (permalink) Old 08-18-2019, 07:38 PM
Originally Posted by fireshine View Post
Ok so how do you measure it is it with the bike on both tires and where on seat is it measured?
Good question. I suppose in the center of the drivers seat. What is it you are trying to figure out?
post #12 of 19 (permalink) Old 08-19-2019, 04:39 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
DBohrer is offline
post #13 of 19 (permalink) Old 08-19-2019, 11:20 PM
BLUTHUNDR31's Avatar
I would think you'd be able to get the ride height by putting the side stand down, lay a yard stick (approx width of my posterior), then straddle the front tire and straighten it upright holding on to the fairing; as you hold it straight have a buddy measure distance from the ground/cement to the bottom of the yard stick. You could put a carpenters' level on the stick so you could see the "bubble" and know when it is straight.
(I'm still wondering why you need the measurement though )
DBohrer likes this.
BLUTHUNDR31 is online now
post #14 of 19 (permalink) Old 08-20-2019, 04:47 AM Thread Starter
fireshine's Avatar
Year: 2012
Model: 2012 1800 nav/xm
i was asked lately if i had a lowering kit on the bike it seems lower then others, it rides fine always 2 up seems ok just curious i am changing out the rear spring this winter to a progressive
sanity,
2014 roll a home wide
2017 africa twin
fireshine is offline
post #15 of 19 (permalink) Old 08-23-2019, 07:17 PM
Nodnocdar
Year: 1992
Make: HONDA
Model: gl1500A/SE
Send a message via AIM to dnagardner
dnagardner is offline
post #16 of 19 (permalink) Old 08-23-2019, 09:56 PM
Originally Posted by dnagardner View Post
that they do:
Seat height 29.1 in (740 mm)
post #17 of 19 (permalink) Old 09-01-2019, 11:31 PM
Great info, , , now the OP can measure the seat height and definitively tell whether or not Wiki is right. HIS beast might not be the same.
post #18 of 19 (permalink) Old 09-02-2019, 06:16 AM
DBohrer's Avatar
Year: 1967
Well, Wiki indicated the GL1500 had (99 bhp) but the Honda Certificate of Origin indicates (96 bhp).
I would trust Honda to know the correct number.......!
The first new model for 13 years, the 2001 GL1800 had a larger 1,832 cc (111.8 cu in) engine with fuel injection, and a power increase from 74 kW (99 bhp) to 87 kW (117 bhp).
DBohrer is offline
post #19 of 19 (permalink) Old 09-02-2019, 09:56 AM
snowmoer's Avatar
Model: 1988 GL 1500, 2012 GL1800, 1977 GL1000 2012 KLR 650
My guess is that measurement would be with the rear shock set at 0. With it set at 25, it would be a little higher.
Dan
AMA Life
2012 GL 1800 Level 3
1988 GL 1500
1977 GL 1000
2012 KLR 650
snowmoer is offline
