1988 Carb rebuild question - Steve Saunders Goldwing Forums
post #1 of 1 (permalink) Old 06-14-2013, 04:42 PM Thread Starter
CapeSnowman's Avatar
Year: 1988
Model: GL1500
I've owned an 88 wing for two years now, 51K on the odometer. It has the infamous off idle hesitation so I decided to pull the carbs and rebuild them. The numerous posts for this problem have my head spinning so am going with a 158 primary and 60 secondary (only 50 and 60 in the kit), 2 turns out for the pilot screw (removed the stop on the float bowl to facilitate adjustment). I've done a complete cleaning and my question is should I use any kind of gasket sealer on the float bowl O ring and if so what is recommended? Seems like there was some kind of "goo" on it before.
Any help would be much appreciated.
Thanks, Happy Fathers Day to you all.
KenQ
Keep your faith in God, but keep your powder dry.
Oliver Cromwell
CapeSnowman is offline
  Steve Saunders Goldwing Forums > Forums > Test Forum
86' GL1200 Carb. Rebuild Question westgl Goldwing Technical Forum 12 11-14-2013 06:23 AM
1988 Goldwing Gl 1500 carb rebuild wabo100 Goldwing Technical Forum 2 06-09-2013 06:53 PM
GL1200 carb rebuild question Wing Bucket Goldwing Technical Forum 3 08-10-2010 05:57 PM
78 gl1000 carb rebuild question morriscatt Goldwing Technical Forum 9 10-10-2008 08:22 PM
Another newbe carb. rebuild question Lew Goldwing Technical Forum 6 12-03-2005 11:59 AM
