Honda GL1500 Se Trike Build - Page 2 - Steve Saunders Goldwing Forums
 2Likes
post #11 of 922 (permalink) Old 10-05-2009, 11:09 AM Thread Starter
skip20's Avatar
Got the front forks disassy'ed & got a pair off eBay last night, $145.00 shipped with bottom tree & brace.
Removed the left front brake hose & will be putting both front brake together.
Removed the front brake hose at the rear master & need to get a spacer to remount the bolt. Rear brake master will now be for the rear only.
Started the engine & it runs smooth as silk with good rev's.
Had to replace Vac hose on #4 cyl., & drain the two hoses.
Don't know how old the gas is but smell ok.
Need to wait for front forks before I remove the rear assy. to start setting up the rear end.
Also need to work on the rear diff. gearing, Miata comes with 4.3:1 & 4.1:1, way to high!
Latest Pictures below.
Till next week run safe.
Skip20
GWRRA 78111
PGR 255645
To many projects to finish
skip20 is offline
post #12 of 922 (permalink) Old 10-05-2009, 02:57 PM
skoto1's Avatar
way too low you mean. and if you leave the rearend pinion in the middle you will need to use a constant volosity joint in the rear of the drive shaft. the angle will be to steep and it will bind on you when you first take off. i know this for a fact. i had to mod mine this way. but your not using the same rear as i did so maybe not. by the way how wide is that rear end.
PGR # 190570
cc permit
1988 1500 trike to be
1980 cb900 custom
gl 1988 1500 trike sold
2003 flhtuci sold
gl 1986 1200 trike sold
gl 1984 1200 trike sold
first bike cb 160 honda
to many to list in between
skoto1 is offline
post #13 of 922 (permalink) Old 10-13-2009, 06:35 PM Thread Starter
skip20's Avatar
The forks came in so I worked at getting them set up.
I WOULD ALSO LIKE TO THANK MEMBER "SKOTO1" FOR HELP IN GETTING THE DRIVE SHAFT ADP. CUT FOR ME.
I WILL ALSO BE LOOKING FOR A COMPLETE FAIRING ASSY, PM & LET ME KNOW IF YOU HAVE ONE.
Skip20
GWRRA 78111
PGR 255645
skip20 is offline
post #14 of 922 (permalink) Old 10-14-2009, 03:28 PM Thread Starter
skip20's Avatar
Well, I moved Little Spitty out to the car port for winter storage & moved the GoldWing into the garage.
Disassy'ed rear of bike, removing tire, brakes, pipes, shocks & trailing arm.
Cut the bag support off leaving only the trunk support.
Rolled in the Miata rear end & checked drive shaft clearance. It's a little tight, but I won't have any up/down movement on shaft.
Have an idea on how to mount rear to bike frame uasing some 2"x3" tubing I have laying around.
Plan to add fuel tank on top of rear end.
Not sure on wheel base as yet, will be what the drive shaft will gave me.
Still need to work on gearing ratio down to at least 2.93:1 which is same as bike.
Thinking maybe a BMW diff.
The tires are 4-100mm x 16" x 8" rims.
Any ideas please post, could help me not make mistakes.
Skip20
GWRRA 78111
PGR 255645
skip20 is offline
post #15 of 922 (permalink) Old 10-15-2009, 12:53 PM Thread Starter
skip20's Avatar
Here is the mock up of the rear frame
Skip20
GWRRA 78111
PGR 255645
skip20 is offline
post #16 of 922 (permalink) Old 10-15-2009, 08:23 PM
Very interesting. I am really enjoying this process.
Anxious to see how it comes along.
NASR 12 in Galena, IL
post #17 of 922 (permalink) Old 10-16-2009, 11:27 AM
lionelgo50's Avatar
Wow!!! I'm getting some good ideas off this. I'd sure like to see the outcome. I might try it someday myself. Kepp us posted of the progress. Great Pictures!!!!
Dave
Dave
Ride Safe and Ride Often, Keep the Shiny Side up and Many Happy Miles and Smiles.
In God We Trust; All Others Must pay Cash!!!
Current Goldwing 2016 Gl1800 Matte Silver
Other Rides
2007 Honda 110cc
Past Rides
2 1985 Goldwing Aspencades, 2006 Harley Davidson Sportster 1200, 2006 Goldwing Navi, 2007 Honda Rebel, 1994 1500cc Goldwing Interstate, 2010 Gl1800 Trike, 1997 GL1500 SE, 2012 Harley Davidson Heritage Softail
lionelgo50 is offline
post #18 of 922 (permalink) Old 10-16-2009, 06:27 PM
SpiderBob's Avatar
You got one heck of a project going there. Looks great. But really, only some people are going to see the real workings at this point of the game and find a lot of interest in it.I be one of them. Post often as you go.
Great job.
Spider Bob
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
"If a man does not keep pace with his companions, perhaps, it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away."
Patriot Guard Rider
SpiderBob is offline
post #19 of 922 (permalink) Old 10-16-2009, 10:06 PM
yes, I am also very interested in your project.
Please take a lot of pictures and allow us to learn as you go.
not2old2wing likes this.
post #20 of 922 (permalink) Old 10-17-2009, 02:51 AM
big al59's Avatar
Going to be taking the easy route and purchasing a bolt on kit .
Think its brilliant when you can build a trike from the ground up,your progress is certainly interesting reading
1995,SE,20TH ANNIVERSARY;CANDY APPLE 2 TONE RED
TRI WING TRIKE!!!
Proggresive 416 shocks,
American racing Anson sprint Wheels.
3 WHEELS ON MY WAGON AND ENJOYING EVERY MINUTE!!
big al59 is offline
1993 Honda GL1500Se Trike build skip20 Trikes, Trailers and Sidecars 546 10-21-2015 08:21 PM
GL1500 trike build ade747 Goldwing Technical Forum 27 06-01-2013 04:56 PM
GL1500 trike build ade747 Goldwing Technical Forum 27 03-31-2013 03:43 PM
GL1500 trike build ade747 Goldwing Technical Forum 47 10-21-2011 04:31 PM
1993 Honda GL1500Se Trike build is now a Sticky AZgl1800 Goldwing Technical Forum 2 08-18-2010 09:55 AM
