Ok I guess I will be chronicling my sidecar build and install. - Steve Saunders Goldwing Forums
post #1 of 28 (permalink) Old 06-24-2010, 08:53 PM Thread Starter
copper204's Avatar
Model: GL1200A
Send a message via Yahoo to copper204
Post Ok I guess I will be chronicling my sidecar build and install.
Ok I have picked up the sidecar. It is supposedly a Spirit America. From the research so far it appears to be the protoype that California sidecar created the Friendship.
It is made of very thick ABS black plastic.. Can you say heavy? It has no cracks and supposedly has been being kicked around in back of garage for years. the frame has had the old swing arm and wheel removed. I plan on using a 500# torsion bar style swing arm. I am then gonna install a 12 inch style spoked trailer wheel and put a chrome wheel cover on it... Custom made cover of course.
I am going to weld in a solid 1/4 thick steel plate in the very middle. I then use this to mount the new torsion swingarm and also mount the hack down to the frame in eight points instead of the four it originally had. This way i know it will be more secure.
This all will be mounted to the GL1100A I am currently bringing back to life.
I am looking for mounts for the frame to body. I am willing to swap parts or cash. If parts it will be swap plus free shipping.
Tell me what ya all think. This is the way I can see that I can get back to riding, and look cool at it..
Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE\'S AWAKE"
and
copper204 is offline
post #2 of 28 (permalink) Old 06-24-2010, 09:06 PM
82gl1100iWingman's Avatar
What year model 1100? 82 was the best year of ALL Goldwings to be the tug.
To my beloved wife Carol, may she R.I.P 6-3-2012 @ 7:35 pm
You will forever be on my finger and forever in my heart.
Miles of 1-13-16
1977 GL1000 Nekkid Wing - 19,1000
1979 GL1000 Nekkid Wing - 58,180
1982 GL1100 Interstate - 100,000
1982 GL1100 Aspy (parts bike) - 61,522
1985 V45 Magna - 50,985
1986 GL1200 Aspy with Champion Escort II Sidecar - 128,911 (odometer broke in 9-12. around 180,000)
2003 GL1800 10,000
Two Wheels Down, Shiny Side Up
GWRRA Member Region H, Tx/Chapter P
82gl1100iWingman is offline
post #3 of 28 (permalink) Old 06-24-2010, 09:12 PM Thread Starter
copper204's Avatar
Model: GL1200A
It is an 1983 Aspencade..
and
post #4 of 28 (permalink) Old 06-24-2010, 09:13 PM Thread Starter
copper204's Avatar
Model: GL1200A
SidecarMike has pointed out many flaws in my plans tho...hmmmmm gonna have to think about extreme beefing up of frame. I plan on fully welding in a 1/4 inch thick plate steel in the middle to fill the entire middle with a second brace running down the middle. This will in effect gusset the corners. I will also be putting fill pieces of same steel plate in both the ends. I will then mount the torsion axle to the plate steel.
and
post #5 of 28 (permalink) Old 06-24-2010, 09:20 PM Thread Starter
copper204's Avatar
Model: GL1200A
Another picture of frame. I will beefing it up. Mike says he does not believe it would be good for my application? I have a tendency to agree with him, since he has obviously been riding hacks for a heck lot longer than me...lol
The frame is solid.. But needs attention.
and
post #6 of 28 (permalink) Old 06-24-2010, 09:24 PM Thread Starter
copper204's Avatar
Model: GL1200A
This is where the Previous Hacker....lol Like that? hacked the swing arm and wheel off....like that too? once again I plan on installing a torsion bar swing arm to the center steel when I weld it in.
and
post #7 of 28 (permalink) Old 06-24-2010, 09:30 PM Thread Starter
copper204's Avatar
Model: GL1200A
This is how I plan to install the sheet steel. The extra weight might even be good for stability? The blue area is where I would install plate steel. I suck at paint shop.....lol
and
post #8 of 28 (permalink) Old 06-25-2010, 06:59 AM
Lightin's Avatar
Copper204, I don't know anything about Sidecars But I do want to say Good Luck In your Project and I wish you much success.
And be riding soon.
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
Lightin is offline
post #9 of 28 (permalink) Old 06-25-2010, 08:32 AM
SidecarMike's Avatar
Year: 1996
Make: Aspencade
Model: 1996 Aspencade with a Friendship 3 sidecar & 1994 Special Edition
I need to correct some of the things I said!
First off, when you said a Spirit of America, I was thinking in terms of this;
This is the one I was describing. I didn't know that Spirit ever made the California I that you are showing. Yours is much heavier than the one I talked about.
It did have some failings, but I think you are already past them.
The best thing that happened was the original axle and hub are gone. It was a goofy arrangement that pressed together with a bronze bushing that wore very fast and would cause the wheel to fall off. If you go with the torsion axle, pay close attention to it's positioning. My daughter put one on hers and ended up with less than an inch of clearance between the top of the wheel and the body. Every time she hit a bump it would rub the glass.
The next problem area is the two lower mounts. They are cups that attach to small balls on the motorcycle frame. The trouble is the balls are too small and tend to shear off at the most inopportune times. They are about 1/2 the diameter of the ball mounts on an old BMW or Ural.
Here is a kit that Dauntless (http://www.mysidecar.com ) sells to fix that problem and mount this frame to your bike. You just remove your lower mounts and, I believe these will slide right in and clamp down. The ends with the bolts are heim joints that fit in to the two lower brackets shown. The upper two will mate with your existing adjustable rods. You should have two of those upper rods.
This frame is nearly twice the size of the one I described in my PM. You will not need that 1/4 inch plate, though you may still want to throw a bag or two of lead shot behind the seat for weight.
Sorry I tried to scare you off. This one will mate well to even a 1500 Wing.
SidecarMike
A motorcycle is like a cast iron skillet, it mellows with age, wash it and you destroy years of seasoning!
The Mistress, 1996 Aspencade & Sidecar 1997 Valkyrie, the Borderline Outlaw
SidecarMike is offline
post #10 of 28 (permalink) Old 06-25-2010, 11:08 PM Thread Starter
copper204's Avatar
Model: GL1200A
I have been e-mailing back and forth with HACKN in www.sidecar.com. He is confirming that the hack I have is apparently the prototype for the friendship. I wonder if that makes it more valuable and maybe I should not hack it up? nah... I will strengthen it with the plates. this will add weight and piece of mind. I will then be using the plate as the mounting point for the torsion. I will oval the mount holes so I can set specific toe in, and camber. i did this same type thing to my old friendship. It made it stable and also with oval holes I was able to ridged and straight. By this I mean the cart body was perfectly straight with bike frame. I used the adjustable holes and metal shim washers to set camber and toe in. I actually stole this from a guy from England that had posted it on the net years ago. The neat thing for me is a welder buddy. He will place the frame on his plasma table and trace the areas to be filled. The laser will then cut those pieces to a perfect fit.. Last time we had to slightly pursuad the piece into the frame. Th is will also allow me to better install the body securely. Yeah you had me scared. we will mount this up to the project bike. This way i will get it all figured out. It will then be removed and sold to my brother.. The hack that is. I have found another hack up in Redding, California. the guy wants a reasonable price for. It is a newer friendship 11.
HACKN appears to have the mounts I will need for this one. Probably the same mounts you were nice enough to show me in your post..
and
GL1500 noise filter install and oil gauge install questions.... gaspredator Goldwing Technical Forum 4 06-30-2011 10:31 PM
Anybody ever build.... Big Port Jimmy 6 Goldwing Technical Forum 6 04-04-2010 12:12 PM
install dyna-eletronic/remove points/76-1000 wing install TOM FOREMAN Goldwing Technical Forum 9 03-24-2010 07:16 PM
Do you think they will build this..........????? Papajoe Miscellaneous Forum 6 07-08-2008 10:30 PM
How they build it !!! wingdawg101 Fun Forum 3 12-30-2007 10:12 AM
