GL1800 Goldwing Trike Build with Pictures - Page 16 - Steve Saunders Goldwing Forums
post #151 of 264 (permalink) Old 02-17-2012, 02:35 PM Thread Starter
Cobra 1800's Avatar
The under side of the tripple tree. Under the cover in the center is where the turn signal cancel switch is located at. It runs down the center tube and connect here.
Cobra 1800 is offline
post #152 of 264 (permalink) Old 02-17-2012, 02:37 PM Thread Starter
Cobra 1800's Avatar
Here is the front view of the forks reasembled.
post #153 of 264 (permalink) Old 02-21-2012, 02:38 AM
ade747's Avatar
Cobra 1800 wrote:
When building the ladder bar make sure you have the body on first to see where the rearend is center. I also took measurments from the center of the axle and outside of the axle to make sure it was square and not shifted. After everything is square I marked the jacks stands to make sure it don't move.
hello,just to ask what size are those rod ends.having only two at the front can the bars move sideways?nice looking job,
ade747 is offline
post #154 of 264 (permalink) Old 02-22-2012, 04:44 AM Thread Starter
Cobra 1800's Avatar
ade747,
The rod ends are 1/2inch and I tied them into the original place the swing arm came out of. I took the end caps that hold the original swing arm and drill a 1/2inch hole in the center. I placed a 1/2 extra hard bolt through it and welded on the inside and around the shaft of the bolt on the opposite side at the base. I then cut it off on the right side enought to clear the drive shaft. The finaltime I will put them back on I'll use lock nuts and lock thigt.
post #155 of 264 (permalink) Old 02-26-2012, 03:47 PM
glennuk's Avatar
hi cobra is every thing ok as we haven't had any posts lately?
Glenn/uk Germany,Poland,Holland,Slovakia,Croatia,Slovenia,A ustria,USA,Hungary,Ireland, chec rep,Estonia,Latvia,Lithuania,Romania on a 1988/1500 115.000 miles and rising/new 1800 start again,Italy,Switzerland,Belgium,France,Nurburgring ,Bosnia ,Montenegro ,Luxembourg ,
glennuk is offline
post #156 of 264 (permalink) Old 02-27-2012, 06:31 PM Thread Starter
Cobra 1800's Avatar
I have been working on the body again trying to get some primer on it and getting some undercoat put on the underside. I have spent all day Saturday on that and will start posting some more pictures within the next few days. Next is disasembling shocks, shock mounts,and placing the body on the frame to install to the existing bike frame. Due to how the body is made I can't assemble everything and then place the body over it all.
post #157 of 264 (permalink) Old 02-27-2012, 06:56 PM Thread Starter
Cobra 1800's Avatar
To answer the question on if the ladder bar would let the rearend slide from side to side the answer is no. With the two ladder bars comming back on each side and connecting to the rearend I have a 1" tube with rodend the connect directly across to tie the left side and rightside together. Then from the left side I have another tube that goes from theleft front to the right rear ladder bar. This keeps the rearend from shifting left to right and shifting. I'll go back over some of my pictures to see if I can post that part again
post #158 of 264 (permalink) Old 02-27-2012, 07:07 PM Thread Starter
Cobra 1800's Avatar
This picture shows the ladder bars and the two tubes that was describe. When setting this up you have to install both ladder bars but preload one side. By preloading one side is adjusted about 2" higher than the opposite side and then push down onto the bolt. This keeps pressure and the slack off. As seen in this photo the cross and diagonal tube keeps the rearend in place and stops any shifting from side ways or drifting. Hope this help answer that question
post #159 of 264 (permalink) Old 02-28-2012, 02:37 AM
Lightin's Avatar
Looking good keep up the good work
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
Lightin is offline
post #160 of 264 (permalink) Old 02-28-2012, 06:41 PM Thread Starter
Cobra 1800's Avatar
Thanks Lightin,
Hope you are doing well. I'm trying to fit mufflers and seeing where I can puthangersat. It's really getting compact under the body. I'm trying to work an hour or two after work to finish up alining the body to the frame and side covers. I still have to run brake lines, wiring harness, and extra support.
non goldwing trike build athomas81 Goldwing Technical Forum 29 11-21-2013 08:34 PM
Trike Build Threads AZgl1800 Trikes, Trailers and Sidecars 5 04-29-2010 09:59 PM
GL1500 GoldWing PARTS trike convert, addition Pictures skip20 For Sale/Wanted Forum 1 11-30-2009 06:16 PM
