GL1800 Goldwing Trike Build with Pictures - Page 17 - Steve Saunders Goldwing Forums
post #161 of 264 (permalink) Old 03-03-2012, 06:33 PM Thread Starter
Cobra 1800's Avatar
Today started working on the brake lines for the back calibers. I had two steel braded lines made up. To connect I applyed the foot pedal to see which hose let the brake fluid out first. That line went to the right side and the other line went to the left.
Cobra 1800 is offline
post #162 of 264 (permalink) Old 03-03-2012, 06:47 PM Thread Starter
Cobra 1800's Avatar
Now comes the hard part. Trying to get the body lined up to the frame and to the front side covers. The frame had to be attach first at the front lower part and then the body next. The trunk stay has to go after the body is in place andthe shocks mounts goes on the outside of the trunk stay. After everything is in place the rear frame is now raiseso the top mounting bolts can go to the bike frame. I wish I could have bolted everything first then slide the body over but it won't clear the shocks mounts and front frame.
post #163 of 264 (permalink) Old 03-03-2012, 06:49 PM Thread Starter
Cobra 1800's Avatar
Here are some pictures after getting everything bolted. Checking alinements and tire clearence.
post #164 of 264 (permalink) Old 03-03-2012, 06:52 PM Thread Starter
Cobra 1800's Avatar
Showing the trunk stay mention eariler. That had to be installed after the body.
post #165 of 264 (permalink) Old 03-03-2012, 06:57 PM Thread Starter
Cobra 1800's Avatar
Here is where I'm looking at the tire clearence. Theleft side has a little adjustment but the right side has too much clearence behind the tire. I'll have to detach the ladder bar and move the axle back.
post #166 of 264 (permalink) Old 03-03-2012, 07:01 PM Thread Starter
Cobra 1800's Avatar
Now that I have the body in place I went ahead and bolted the body to the frame. I'll come back later and adjust the axle so I have equal distance.
post #167 of 264 (permalink) Old 03-03-2012, 07:14 PM Thread Starter
Cobra 1800's Avatar
At this point I won't take the body off any more. I will paint the body on the bike to keep from scratching and also to spray everything at the same time. Candy paint will change shades with different air pressure and adjustments of the spray gun. That is why I want to have everything ready to spray so I won't end up with different shades of color. That part is still aways off.
post #168 of 264 (permalink) Old 03-06-2012, 12:05 AM
Lightin's Avatar
It looks like a trike you are doing a good job .
after you have bleed the brakes get the pedal pumped up and either tie down or I use a short screwdriver. to wedge it down leave it there forget about it while you do the other stuff after several days ,a week or so all the micro fine bubbles will work up to the resivor and escape out the tiny vent hole you will have the best brakes. then keep up the good work and shareing with us.
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
Lightin is offline
post #169 of 264 (permalink) Old 03-06-2012, 10:53 AM
skip20's Avatar
Looking good, cant wait for you to swing by for a test drive & cruising.
The Candy RED will look good next to the Pearl YELLOW!
GWRRA 78111
PGR 255645
To many projects to finish
skip20 is offline
post #170 of 264 (permalink) Old 03-08-2012, 03:44 AM Thread Starter
Cobra 1800's Avatar
Thanks Lightin,
I had my wife pumpthe pedal several time while I open the bleeder valve but I will take your advise and do that. Always good to have sound advise. That why I like this site.
non goldwing trike build athomas81 Goldwing Technical Forum 29 11-21-2013 08:34 PM
Trike Build Threads AZgl1800 Trikes, Trailers and Sidecars 5 04-29-2010 09:59 PM
GL1500 GoldWing PARTS trike convert, addition Pictures skip20 For Sale/Wanted Forum 1 11-30-2009 06:16 PM
