Trike Build - Page 14 - Steve Saunders Goldwing Forums
post #131 of 185 (permalink) Old 04-13-2015, 09:08 PM
Bob Myers's Avatar
Model: 1995 Interstate
What did you end up deciding the rear axle was? Mustang/Ranger? 7.75 ford?
if it is 7.75 Ford i can get 3.55 gears fairly easily, most my off road friends throw them away
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
Bob Myers is offline
post #132 of 185 (permalink) Old 04-13-2015, 09:33 PM Thread Starter
jammer's Avatar
Year: 1990
Model: GL1500SE/ Trike
6.75 pinto. I'm thinking 2.73's
jammer is offline
post #133 of 185 (permalink) Old 04-13-2015, 09:48 PM
Model: Endeavor Trikes (4)
Originally Posted by jammer View Post
Sorry Bob. well first time out and Found the steering to be Something that wants to control itself. Lots of wobble in the steering and resistance in the steering. (hard to steer) This is how I started tire pressure-----20 .lbs in the rear tires and 31 .lbs front. went to i think 39 front and 30 rear. I spoke to someone that has built a couple and his suggestion was 41 front and drop the left rear to 20 and right rear to 22. Or lower in rear if needed but keep the 2 pond split in rear. In addition the rear gear selection seems to high. (308) I have the stock tree as well.
Steering is something you will have to get used to as you are running 30 degrees of caster which is a lot. The offset trees help as they reduce the trail (does not change the rake) but it will still do the waddle and at times be hard to steer.
18-22 psi is about right on the rear as anything more and you will experience bounce and poor tire life. 35 is about right on the front and bias plys tend to ride softer too.
Here is an example of what you are up against on the 30 degree rake (caster) http://ido-endeavor.com/why-reverse/
I guess the best advice I can offer is to just ride and get accustom to the handling, in time it will feel more natural.
I put 120k on my trikes before I ever rode a standard trike and believe me it was an unexpected and enlightening experience. Since then I have ridden several brands of conventional trikes and found they all run about the same but now it's becoming natural even for me.
storm is offline
post #134 of 185 (permalink) Old 04-14-2015, 07:58 AM
Bob Myers's Avatar
considerably more difficult to find but will check. I suspect that axle came from an automatic, a standard Pinto/Bobcat will have a lower, maybe the 3.08
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
post #135 of 185 (permalink) Old 04-14-2015, 07:10 PM Thread Starter
jammer's Avatar
Year: 1990
308 is what i have now. It's turning to many R's compared to the stock ratio.
jammer is offline
post #136 of 185 (permalink) Old 04-14-2015, 08:11 PM Thread Starter
jammer's Avatar
Year: 1990
Not 100% sure on my front tire? Bias or radial on the front of a trike??? 4.5 or 6 degree. I thought some where I saw a formula to calculate wheel base and so on.
jammer is offline
post #137 of 185 (permalink) Old 04-14-2015, 08:28 PM
Bob Myers's Avatar
There is a 2.79 ratio available, tag will read WDY-AS likely an automatic pinto or Bobcat. Ford always put a higher ratio in automatic than standard
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
post #138 of 185 (permalink) Old 04-14-2015, 08:44 PM Thread Starter
jammer's Avatar
Year: 1990
O:k. I want to tackle the hard steering issue first I guess before moving onto the ratio. One thing I thought about earlier was the f-tire. I'm not sure if I have bias or radial. I'm sure I want a radial on the front.
jammer is offline
post #139 of 185 (permalink) Old 04-14-2015, 08:53 PM
Bob Myers's Avatar
Checking with a guy in Oregon, he may have a triple tree, will advise when i know
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
post #140 of 185 (permalink) Old 04-14-2015, 08:59 PM Thread Starter
jammer's Avatar
Year: 1990
Ok that would be great. Thanks bob.
jammer is offline
GL1500 trike build ade747 Goldwing Technical Forum 27 06-01-2013 04:56 PM
New Trike Build, Not GoldWing skip20 Goldwing Technical Forum 12 05-28-2013 10:11 PM
Trike Build Threads AZgl1800 Goldwing Technical Forum 4 04-29-2010 08:07 PM
