Trike Build - Page 16 - Steve Saunders Goldwing Forums
post #151 of 185 (permalink) Old 04-22-2015, 07:58 PM
Model: Endeavor Trikes (4)
Originally Posted by jammer View Post
O:k. I want to tackle the hard steering issue first I guess before moving onto the ratio. One thing I thought about earlier was the f-tire. I'm not sure if I have bias or radial. I'm sure I want a radial on the front.
I would recommend a bias they tend to ride softer and can do with less air than a radial.
The Bridgestone BT45R is a really good bias.
Offset trees will help with the 30 degrees of rake by lessening the trail (doesn't change the rake) however the added 4-6 degrees of tube angle will cause more sticktion and therefore slightly harsher ride. The extra angle will also lower the front slightly so you may also wish to go with extenders.
Unfortunately you can't change the rake without cutting the frame head but the above changes will help a bit.
In general with the 1-2 conversions you just get used to the hard steering in time.
storm is offline
post #152 of 185 (permalink) Old 04-22-2015, 08:36 PM Thread Starter
jammer's Avatar
Year: 1990
Model: GL1500SE/ Trike
So radials on the rear and bias on front???
jammer is offline
post #153 of 185 (permalink) Old 04-22-2015, 09:36 PM
Absolutely MC radials are nothing like auto radials. Actually the mc bias is a closer match than the radials. Problem with MC radials is they are hard as rocks and ride pretty rough because of that.
You can mix and match tires on a motorcycle all you want as it does not matter.
storm is offline
post #154 of 185 (permalink) Old 04-23-2015, 07:58 AM
Blue3red2's Avatar
Model: GL1200 Aspencade Trike
I used 84 Ford Ranger rear/axles, 4 bolt, 15 x 7 on my trike. Tire size is 215/65/15. If my rims Mustang, 4 bolt) were a bit narrower (6") I would have used 205/70/15. But the difference wasn't that much as I changed gearing to 3.00. If needed one can re-drill the axle, install 4 studs. We're not running 600 horsepower on these trikes.
Run rear tire pressures from lows of 12-16 (left/right) to 20/22-24 (left/right) and front tire (40). Rear air shocks about 40-ish lbs. Front air fork pressure: 5-6 lbs.
My trike is a 1985 GL1200 Aspencade, narrowed Ford Ranger rear with a 1996-8 GL1500 MotorTrike body. Also installed 5 degree steering. I built it in 2008 and is still running great.
B3r2
Blue3red2 is offline
post #155 of 185 (permalink) Old 04-23-2015, 02:45 PM Thread Starter
jammer's Avatar
Year: 1990
I am at 40 front. 20 LR 22 RR. Have not been out yet to try it. Have not done the air fittings yet for front forks. Blue3 how did you do your 5 degree? A new tree or cut and weld the head. And I did forget about the ranger runs 15" on four lug.
jammer is offline
post #156 of 185 (permalink) Old 04-23-2015, 03:07 PM
Blue3red2's Avatar
jammer, bought 5 deg. tree (expensive for GL1200...GL1500 are cheaper). Had too as the wife drives the trike. ;-) Like I said...try those pressures and lower rear more IF needed. I still worry about your air bag. Just a bit much as a auto bag (7" size ) is enough for all weights carried. Only need in the range of 20-30lb pressure.
Leaving for supper right now. Get back later on FaceBook.
B3r2
post #157 of 185 (permalink) Old 04-23-2015, 03:41 PM Thread Starter
jammer's Avatar
Year: 1990
ok Get in touch
jammer is offline
post #158 of 185 (permalink) Old 04-23-2015, 07:10 PM
Bob Myers's Avatar
Model: 1995 Interstate
4 lug on Ranger? Never seen one, yet. There were 4 lug 15" wheels for Mustang and Capri. My 78 Fairmont had 4 lug 15" wheels
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
Bob Myers is offline
post #159 of 185 (permalink) Old 04-23-2015, 08:23 PM Thread Starter
jammer's Avatar
Year: 1990
I thought for sure ranger was 15" Been building mustang race cars for 10 years. never saw a 4 lug 15" mustang. (you did say fairmont)
jammer is offline
post #160 of 185 (permalink) Old 04-23-2015, 08:32 PM Thread Starter
jammer's Avatar
Year: 1990
B3R2 Is your concern for the heft of the bag? It will fully extend before it gives out.
jammer is offline
GL1500 trike build ade747 Goldwing Technical Forum 27 06-01-2013 04:56 PM
New Trike Build, Not GoldWing skip20 Goldwing Technical Forum 12 05-28-2013 10:11 PM
Trike Build Threads AZgl1800 Goldwing Technical Forum 4 04-29-2010 08:07 PM
