Trike Build - Page 17 - Steve Saunders Goldwing Forums
post #161 of 185 (permalink) Old 04-23-2015, 09:27 PM
Bob Myers's Avatar
Model: 1995 Interstate
Originally Posted by jammer View Post
I thought for sure ranger was 15" Been building mustang race cars for 10 years. never saw a 4 lug 15" mustang. (you did say fairmont)
My old 4 cyl ranger was 14", my stepfather had one same year, with a 2.9, it had 15" wheels and tow package, but all were 5 lug
Here is a stock 87 Mustang 15" wheel
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
Bob Myers is offline
post #162 of 185 (permalink) Old 04-29-2015, 08:02 PM Thread Starter
jammer's Avatar
Year: 1990
Model: GL1500SE/ Trike
I'll check to see if I can locate a set of gears first, If not I'll be putting bigger tires on her.
jammer is offline
post #163 of 185 (permalink) Old 04-30-2015, 10:05 AM
Year: 1981 1100I [being triked now] 1995 1100 ACE & triked out 1100A
Make: Hondas
Model: 1981 1100i
Jammer, While you are looking for your rake kit, and if you run across a 5 degree for a 81 GL1100I, Please let me know! Still doing body work on mine, But it will not be long before paint, Thanks Charlie
Charlie in nc is offline
post #164 of 185 (permalink) Old 05-02-2015, 08:59 AM Thread Starter
jammer's Avatar
Year: 1990
Will do Charlie
jammer is offline
post #165 of 185 (permalink) Old 05-23-2015, 06:08 PM
Magic Moderator
trike lady's Avatar
Jammer I am sorry for not being here to answer your PM and to Charlie in NC I have a site where you can buy raked triple trees for older Wings.
http://www.customtripletrees.com/TREES/HONDA/honda.html
Retired trike builder.
trike lady is offline
post #166 of 185 (permalink) Old 05-24-2015, 10:10 PM
Make: Hondas
Model: 1981 1100i
Trike Lady, Thanks for the return, I have been in touch with Bill, But hoping to find one a little more cheaper, 1080.00 plus bearings is a little more than I want to spend at this time, [got to clean up some cards] Jammer, Thanks for the return, What size is your 3rd member, Thanks Charles Franz
post #167 of 185 (permalink) Old 06-04-2015, 08:38 PM Thread Starter
jammer's Avatar
Year: 1990
I have a 79 pinto rear with 6.75" I have 308 right now and In need of 273 Ish.
jammer is offline
post #168 of 185 (permalink) Old 06-04-2015, 08:54 PM
Bob Myers's Avatar
did you call the guy i sent you a message about? supposedly he has this
1993 GL1500 I
1988 Vulcan 800A
1986 Yamaha Venture
N4RWM
post #169 of 185 (permalink) Old 06-22-2015, 07:17 PM Thread Starter
jammer's Avatar
Year: 1990
Sorry Bob. NO I have not called yet. Racing season has started, So my spare time is limited through the summer. I wrote a note to call them tomorrow. Thanks again.
jammer is offline
post #170 of 185 (permalink) Old 09-27-2015, 02:05 PM
CrystalPistol's Avatar
Just read most of this thread for the first time. If your new trike has the newer '70s / 80s sized 4 lug Ford pattern (4 holes X 108 mm (4.25") circle using 1/2-20 studs) as used on almost all Fox bodied Fords (T-birds, Cougars, Mustangs) and Pintos, then yes .... there are a bunch of 15" wheels available as that includes 1979-1993 Mustang GTs (*not SVO) as well as those '83-'88 Thunderbirds and T-bird Turbo Coupes (that even came with 16" wheels in 1987 / 88).
My Lehman trike uses a Ford 6.75" rear housing cut down with 3.08:1 gearing, uses new shorter axles, Ford 1.75x9" drum brakes, 7/8" diam wheel cylinders, 15x7 ASA 5 spoke wheels (I even picked up a spare pair off ebay a few years ago) and Lehman shipped Dunlop GT Qualifier 245/60-15 tires with the kit. I had a '85 Thunderbird with "10 hole" Ford 15x7 wheels and it had same exact lug pattern and back spacing as the wheel Lehman shipped. When tires needed replacement, I went with 215/70-15 Lemans HR tires which are same OD, weight 4 pounds less per tire, are 1" narrower overall ..... and I installed longer Morosso studs and used some 1/2" spacers to bring the tire sidewall back out near fender for asthetics sake.
3,000 rpm in 5th is near 65 mph as I recall. I had a picture ..... I'll look closer.
The old Ford 4 lug pattern (4 holes X 114.3 mm (4.5") circle using 1/2-20 studs) as used on Falcons and 6 cyl Mustangs in the '60s is different, that is the same pattern used by Motor Trike I believe. I am not sure of other manufacturers.
Easy to measure, 4 lugs, measure across center to center of lugs. There are also aftermarket 4 lug wheels made in a dual lug pattern.
...(Candy Spectra Red )
CrystalPistol is offline
GL1500 trike build ade747 Goldwing Technical Forum 27 06-01-2013 04:56 PM
New Trike Build, Not GoldWing skip20 Goldwing Technical Forum 12 05-28-2013 10:11 PM
Trike Build Threads AZgl1800 Goldwing Technical Forum 4 04-29-2010 08:07 PM
