cruise control slows down over time - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 02-21-2016, 03:06 AM Thread Starter
Make: honda
Model: GL1500 w/ champion daytona 2+2 sidecar
GL1500 with large sidecar. Not sure what is causing it. It has a new cruise control air filter on it. If you set it at 75, about 10 minutes later you are going 68 or so. I haven't found any vacuum leaks but I honestly am not sure where to look for this particular problem. I've checked every hose i ran across and all seem to be OK. I've never owned a bike with a vacuum controlled CC before.
Also if you just hit the set button at 75 it will actually set about 71 if you just let go of the throttle as soon as the set light comes on. Gives the passenger in the hack kind of rush when that happens if it does.
So I hit the set switch then hold the accell switch on till I feel the cruise take the slack out of the throttle then I release it. It will run down the road for 3 or 4 miles fine then it start to slowly drift down. Sometimes it takes longer than others. Tonight it took about 7 miles for it to drift down 5 mph then I woke up as cars began passing me . Then I bumped it up again. I'd like to fix it if I can.
Joe_ is offline
post #2 of 5 (permalink) Old 02-21-2016, 07:08 AM
You probably need to adjust the slack out of the actuator cable so it sets without so much hesitation but other than that I have no idea. It's supposed to maintain X speed electronically, doesn't make sense it would slow down.
post #3 of 5 (permalink) Old 02-21-2016, 11:52 AM
the 1500 cruise typically sets lower than the speed you are at.
As Dave said, the cable needs to be adjusted to cause it to pull slightly harder when it is set.
77 is about the max speed it can be set at, unless you make the mod to swap the 4th and 5th gear wires to the cpu.
Cruise Control Issues
1500 Cruise Control Button - Steve Saunders Goldwing Forums
95 GL1500 cruise not working.
Beating The ~80 MPH Limit of the GL1500's Cruise Control
Cruise Control not engaging
Cruise Control Ultra Cruise - Complete Electronic Cruise Control Syste (...)
Erratic Cruise Control on a '92 GL-1500A - Goldwing Technical Forum - (...)
GL1500 Cruise Control lag fix
GL1500 Cruise Control Problems
GL1500 Cruise control speed limit & CB issue.
GL1500 SE Cruise Control Fix by AZgl1500
Re Setting the Cruise Control
3 Good Links to fixing the Max Speed issue
post #4 of 5 (permalink) Old 02-21-2016, 09:36 PM
CrystalPistol's Avatar
The time or two I have used it on our '97 ..... it also would set, appear to hold and soon you'ld be 5 mph slower.
I use my Vista Cruize throttle locks on both it and the '85 regularly. It's a habit from my formative years on British bikes with grubbing screws. Just enough tension to hold it if I let go is just enough to yet allows throttle adjustment with a twitch.
...(Candy Spectra Red )
CrystalPistol is offline
post #5 of 5 (permalink) Old 02-22-2016, 09:37 AM Thread Starter
Make: honda
thanks for the quick replies and the list of links.
Joe
Joe_ is offline
  Steve Saunders Goldwing Forums > General > Goldwing Technical Forum > Trikes, Trailers and Sidecars
Is the 92 SE starter/cruise control different from the non-SE control chas Goldwing Technical Forum 6 11-23-2014 07:41 PM
GL1200 slows down like you put the brakes on Keith Hertzog Goldwing Technical Forum 36 01-05-2014 11:32 PM
cruise control domel New Members Introduction Forum 12 05-05-2009 09:26 PM
'98 SE slows/drags down while riding louieg Goldwing Technical Forum 5 12-09-2008 09:50 AM
GL1500 Cruise Control and Emissions control equipment IanB Goldwing Technical Forum 6 08-22-2006 06:04 AM
