'93 gl1500 advice on 4* timing gear needed - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 09-27-2017, 06:43 PM Thread Starter
anyone install a 4* timing gear in the 1500 engine? whats your advice. thanks
eagle1 is offline
post #2 of 2 (permalink) Old 09-27-2017, 08:13 PM
Magic Moderator
trike lady's Avatar
The 4* timing wheel is used mainly by those who own 1988 or 1989 GL1500 to correct the hiccup that those bike experienced. Honda did correct the problem but some still have the problem. By changing the degree wheel you will also need to run premium fuel. MBL used to make cam sets for the 1500 but there seemed to have been no interest for the upgrade. However may I suggest removing the pre-muffler chamber and adding an X-factor http://www.torqmasterpipes.com/product/x-factor/ Open up the exhaust a little.
When was the last time the trike had a carb sync? A carb sync does wonders for performance and fuel economy.
Retired trike builder.
trike lady is offline
Alternator advice needed '93 gl1500 jlaframboise Goldwing Technical Forum 15 03-14-2015 10:36 PM
GL1500 Advice Needed dvd1955 Goldwing Technical Forum 13 12-23-2013 05:15 PM
GL1100 Advice needed on Gear Oil Grade's Erics Goldwing Technical Forum 4 11-15-2013 05:43 AM
GL1500 Pilot screw advice needed tyashton Goldwing Technical Forum 7 10-21-2013 06:32 AM
GL1500 SE timing belt advice please big al59 Goldwing Technical Forum 7 06-21-2009 07:22 AM
