4 degree vs 6 degree rake - Page 3 - Steve Saunders Goldwing Forums
 12Likes
post #21 of 47 (permalink) Old 06-07-2018, 08:51 PM Thread Starter
jammer's Avatar
Year: 1990
Model: GL1500SE/ Trike
I think I will do the 6 degree.
CrystalPistol likes this.
jammer is offline
post #22 of 47 (permalink) Old 06-10-2018, 03:42 PM
CrystalPistol's Avatar
You'll be happy with either one, but you'll be happiest with 6 if you try both.
IMHO.
...(Candy Spectra Red )
CrystalPistol is online now
post #23 of 47 (permalink) Old 06-10-2018, 05:26 PM
Year: 2003
Model: GL1800/Roadsmith Trike
Either 4 or 6 is much better than stock. On my 1500 trike I had 4.5 and on my 1800 6 degree. Takes a little time to get used to 6 but now it's much better that 4.5. Good luck, let us know how it goes!
Ron Hochhauser
RonHochhauser is offline
post #24 of 47 (permalink) Old 06-11-2018, 08:31 PM Thread Starter
jammer's Avatar
Year: 1990
I have a stock one that has been cut and welded with 4 degree now. The issue is wanting it a little easier as well as safer.
jammer is offline
post #25 of 47 (permalink) Old 09-16-2018, 04:29 PM
Just be aware using cut and welded with no fork tube extensions will lower front of trike some.
post #26 of 47 (permalink) Old 09-16-2018, 04:45 PM Thread Starter
jammer's Avatar
Year: 1990
I have since replaced the tree with a papazook tree 4.5. The only inprovement from the OEM altered one is less wobble at slow speeds over bumps. as for any other improvements it steers a little stiffer when cornering. and this one has the 2" extensions the other did not. thinking of lowering the front end to see what improvements i get from that. Not sure i will mess to much as it is for sale. Time for a new house!!
jammer is offline
post #27 of 47 (permalink) Old 09-16-2018, 05:23 PM
Year: 1986
Make: honda
Model: gl1200A
are yall getting rake with triple trees, head bearings, or frame rake?
claydbal is offline
post #28 of 47 (permalink) Old 09-16-2018, 05:52 PM Thread Starter
jammer's Avatar
Year: 1990
tree's
jammer is offline
post #29 of 47 (permalink) Old 09-16-2018, 05:59 PM
AaronzDad's Avatar
Year: 1987
Model: GL1200A Aspencade
Rake degree doesn't matter. It's the trail that affects handling.
Changing the rake changes the trail.
Front end geometry can be complicated but it's crucial to understand if you're gonna be changing things up there.
Ken Bergen likes this.
AaronzDad is offline
post #30 of 47 (permalink) Old 09-16-2018, 07:26 PM
Just lays fork tubes down, moving tire forward, reducing trail, eases steering. Not a "real rake" as stem angle stays stock. Kicks frt tire forward.
My kit included new machined billet triple trees, new bearings, new stem, two fork extensions. Fork tubes raked 6 more degrees than stem. Trike (bike) frame not altered. This was a Champion 6 degree E Z Steer in 2004.
I neglected photo of tube extensions in 2004 when I did mine? Also I have no pic of top stem bearing, but that was included. I did, in time, cut some black adheasive backed vinyl and cover top of that reflective, very shiney top triple tree. Paint would be OK too.
Tow-Pac + 4.5 degree rake kit & riding on 2 wheels dadztoy Trikes, Trailers and Sidecars 13 04-12-2017 07:44 PM
WTB - 4.5 degree rake kit for GL1800 dadztoy For Sale/Wanted Forum 0 07-11-2016 03:16 PM
6 degree rake xetremex Trikes, Trailers and Sidecars 3 08-23-2014 10:37 AM
Get your MA Degree - ccsailor Fun Forum 1 03-02-2007 06:30 PM
Degree Of Addiction Hawker22 Miscellaneous Forum 36 04-02-2006 04:42 PM
