Trike rearend question: - Steve Saunders Goldwing Forums
 3Likes
  • 1 Post By CrystalPistol
  • 1 Post By SchWing
  • 1 Post By DaveO430
post #1 of 6 (permalink) Old 06-29-2018, 06:36 PM Thread Starter
Year: 1983
Model: Aspencade
I'm planning a trike build with a '93 Aspy. Instead of cutting down the axles to narrow the width and offset the differential to align with the existing driveshaft, I'm thinking of leaving the axle as is and using a jackshaft to run the driveshaft down the center.
Any (constructive ) thoughts on this?
Thanks!!
Rubber down, chrome up, throttle open!!
~Gil
SchWing is offline
post #2 of 6 (permalink) Old 06-29-2018, 06:52 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
Be sure to mount the jackshaft securely to the axle housing . I would consider a 2 or 3" width cogged drive belt instead of a chain drive.
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #3 of 6 (permalink) Old 06-29-2018, 06:52 PM
CrystalPistol's Avatar
I would not even consider a "jackshaft".
My Lehman has the driveshaft coming from output shaft to Ford 6.5" (ring gear dia., 3.08:1 ratio) pinion yoke, and both shafts are to right of center but still not in perfect alignment, so it uses U-joints at each end. Most car rears have the shaft off center to right side, as does your GL-1500... inside the swingarm.
Find a narrow enough axle and you can use wheel spacers to fine tune side to side. Old Pintos & etc used 6.5" rear as in my Lehman, I think some used an 8" rear though that seems a bit overkill.
siouxindian likes this.
...(Candy Spectra Red )
CrystalPistol is offline
post #4 of 6 (permalink) Old 06-29-2018, 08:19 PM Thread Starter
Year: 1983
Model: Aspencade
Thanks!! Jackshaft out!!
~Gil
SchWing is offline
post #5 of 6 (permalink) Old 06-29-2018, 09:29 PM
My Lehman has the driveshaft coming from output shaft to Ford 6.5" (ring gear dia., 3.08:1 ratio) pinion yoke, and both shafts are to left of center but still not in perfect alignment, so it uses U-joints at each end. Most car rears have the shaft off center to left side, as does your GL-1500... inside the swingarm.
That's the right, not the left, I make that mistake I think from years of standing in front of cars and what's on my right is the left and vise verse. I have wondered why the diff isn't offset in trikes to better align the shaft.
CrystalPistol likes this.
post #6 of 6 (permalink) Old 06-29-2018, 09:39 PM
U IS'O RIGHT!
I don't know how I did that . Good catch!
First time into the rearend on '91 gl1500i jpelmer Goldwing Technical Forum 10 09-07-2011 05:05 PM
1993 GW Trike w/ Mustang RearEnd 99winger General Motorcycle Discussion Forum 10 09-12-2010 06:23 PM
82 aspencade1100 two things on rearend krazy al Goldwing Technical Forum 3 06-13-2009 05:49 PM
1500 rearend on 1200 upgrade TJ859 Goldwing Technical Forum 12 08-10-2005 01:48 PM
1500 rearend on1200 upgrade -update TJ859 Goldwing Technical Forum 8 08-07-2005 09:40 AM
