Late dad's trike won't start - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 19 (permalink) Old 06-10-2019, 05:56 PM
Just one of the guys
DougW's Avatar
You say the battery is good, but, were it me, I would put a set of jumper cables on it from a car or truck battery just for giggles.
You could also try putting it in reverse and rocking it back and forth a little while holing the button, if it is a frozen starter that might bump it loose. Just donít get real harsh if you try this, just gently bump it so nothing else breaks.
trike lady and CrystalPistol like this.
Doug
DougW is online now
post #12 of 19 (permalink) Old 06-11-2019, 08:56 AM
New Sidecar guy
Year: 1998
Model: SE/Hannigan Sidecar
Put a volt meter on the battery. Should read close to 13 Volts. Turn the key on and hit the start button while watching the Volt meter. That should give an idea of the state of the battery.
odinjunior is offline
post #13 of 19 (permalink) Old 06-11-2019, 08:34 PM
cihilb's Avatar
Model: 2012 Pearl White
I agree. The bike needs at least 10 volts when trying to start. Try cleaning the battery connections also. A little corrosion will act like a bad battery.
cihilb is offline
post #14 of 19 (permalink) Old 06-13-2019, 06:25 PM
Magic Moderator
trike lady's Avatar
Did you get it running?
Retired trike builder.
trike lady is offline
post #15 of 19 (permalink) Old 06-14-2019, 07:15 AM
Donnyc426's Avatar
My 06 wing had a similar problem. Ended up being a loose connection at the solenoid (located to the right of the battery, behind the trunk). It can be accessed by removing the battery. Tight reach, but you can check for looseness. Best of Luck!
Donnyc426 is offline
post #16 of 19 (permalink) Old 06-15-2019, 09:03 AM
wingingit2's Avatar
Model: GL1000 times 3
You said it would not rock back and forth. It could be hydro locked from fuel in a cylinder or two. Pull the spark plugs and turn kill switch off and put a large rag over each bank. It should crank. Do not stand to the sides near the plug holes the gas will come out with great force and blow over everything.
Lady Luck Prefers the Prepared
wingingit2 is offline
post #17 of 19 (permalink) Old 06-15-2019, 10:03 AM
Not likely with fuel injection and 1800s won't crank with the kill switch off.
post #18 of 19 (permalink) Old 06-15-2019, 11:13 AM
wingingit2's Avatar
Sorry, I had GL1500 on my mind. Even though I read it I am working on an 1500.
post #19 of 19 (permalink) Old 06-15-2019, 02:51 PM
Bellboy40's Avatar
Year: 2000 & 1994
Also, the later model 1500s won't try to start with the kill switch off like the earlier ones did either. I think they changed that in either 97 or 98.
Larry
-- Albert Einstein
Bellboy40 is online now
