01 wing right handlebar cruise switch wires melted. i replaced the switch pod and replaced the 30 amp fuse with the correct 10 amp fuse. has been blowing alt. fuse about once a month for some time but only on trips w/cruise on. looked at my shop manual wiring diagram.cruise gets power from alt. fuse. did wiggle test and visual inspect . Jesus, what a wiring system for a bike! i'm good at this on cars but no one to go to on a Wing. Also i cant find radio light bulbs for radio.
Gregarious Greeter
[align=center]
[/align]
[align=center]Welcome scottwallace[/align]
WELCOME:waving::waving::waving:
I am working on a netbook with no CD drive while my computer gets fixed so I can't be much help right now. Does it blow the fuse only when the cruise is set or any time the main switch is on?
thanks for the reply. i looked on fuse cover, it's fuse#19 IGN CRUISE not alt. sorry. last time it blew cruise switch was on but cruise not ingaged. during tear down i found two wires burned from cruise on "not set or resume" all the way to where it plugs into the main harness. i just plugged in a brand new switch and the bike cranks and runs. i know i repaired the symptom but would to find the cause.would appreciate any ideas.
You are going to be looking for a short in the black/yellow wire somewhere from where the switch connects at the main harness to the cruise/reverse module or through the front brake, throttle switch and rear brake switch which is where I would look first because of your statement that it happens when on the highway because the throttle switch is closed when the throttle is opened and power goes from it to the rear brake switch and back to the cruise module. (brown/red and green/white wires).
Welcome, WelcomeTo Steve Saunders Goldwing Forum.If you have any questions no matter how trivial they may seem this forum is the place to ask them. What I have noticed is that some of the people here were :15red:'sin their previous lives and can answer any question you have. Theforums that I get the most from are::
Goldwing Technical Forum
General Motorcycle Discussion Forum
These have the best info aboutGoldwing’s and are where you ask questions and can get help..
For Sale/Wanted ForumGood stuff for Sale or if you have old parts sitting around the garage you would like to get rid of....
:18red::15red::12red::11red:
And when all you need is a good laugh to start your day try the:: Fun Forum After that it’s up to you which of the others you will like the best all I can do is suggest.
Again Welcome to the Forum...
Oh and did I mention everyone here loves pictures.. Show us some of yours... Even if it’s not a Goldwing just a pretty view
