I have an 02 Wing with a motor trike kit. I am loosing brake fluid from the rear but have NO visible leaks. Have checked all lines and even had someone work the pedal while under the bike. Any ideas?
If you have brake drums on the rear, a leaking brake cylinder will leak into the brake drum, and you might not see it until you pull the drum.
Master cylinder piston may be leaking into rubber gaiter before sign of leakage,also second cylinder may be leaking into drum before showing leakage signs.
