My 06 1800 has a bad wobble, the head bearing needs replacing but I'm having an issue finding a place to do it. Don't want to take it to a place that is going to charge me huge bucks to do it but at the same time I want to take it to someone that knows what they are doing. There has to be a good place in or near the GTA. :stumped::stumped:
Just an FYI, GTA is Greater Toronto Area for anyone that doesn't know the short form.
If you click on Brampton in your profile, you should see 10 forum members from there, even more if you click on Ontario. Send one of the more active members a PM and they might be able to help.
The bearings themselves will not cause a wobble, the wobble is because of something else (tires) , good bearings will however help dampen it out. Check out you tires and find out what is causing the wobble then change the bearings if needed.
Welcome to the Forum grant! :waving:
