Well we replaced the sensor and now the fan kicks on. :clapper:
But, now somethings up with the starter. Sometimes it just kinda grinds like its not engaging, but then itll start just fine. But we had it running and the starter started smoking.My dadthought since its the alternator too that its over charging?(I didnt even know they were one in the same, im just an amiture) So I guess its off to the garage tommorow to have it all checked out by a pro, it needed a check up before the big trip anyways.
---Eric
---Eric
Eric, the starter and alternator (stator) are two different critters. Sounds like you have a short or something wrong with the starter clutch system. There's a lot of info on this forum if you search for starter on the top of the page. One consensus about pulling the starter, keep the bike on the side stand so the sprocket and chain doesn't fall down into the engine.
:waving::waving::15red::waving::waving:
The Irish Crew
Are you sure the starteer button isn't sticking? This would make the starter motor keep spinning when the engine is running and will ruin the starter will wear out very quickly.
Im pretty sure the button isnt sticking. It seems like its over charging or something but I dont know for sure. Once we get it figured out as to what it is ill update.
---Eric
Did you get to the bottom of this problem Eric?When new problems crop up that I haven't heard of, it's nice to know the outcome. :)
