Hey Folks,
I just got an 82 1100 GL Interstate. I cannot find anything about the air suspension other than you just set it at different pressures to adjust ride. My system leaks, and I need to know the protocol to make this work properly. I will first check for leaks on hoses and connections, then go to the shocks and forks themselves, correct? Is there a rebuild kit available for the rear shocks, as I see snap rings at the bottom of the body, and if so, are there any special things, procedures or tricks I need to know? Thanks for the help.
JKN
Hey Folks,
JKN
