front brakes on my wing have been known to stick on after use, result smell of burning pads and not a lot of progress. Usually freed by rocking back and forward
I'm also assuming that this could be the cause of a lack of power when accelerating
Have assumed that it's the return bleed hole in the master cylinder that is the culprit as when I took out the pads the pistons seem free enough moving backward and forward. So have bit the bullet and pulled the master cylinder, when I drained the fluid from the reservoir, empty into a dish after removing cap, I found seddiment in the fluid and in the corners of the reservoir, also in what appears to be the feed drain.
Have managed to pull free the plastic reservoir and looked at the 'feed drain' and can see one complete hole and one hole that appears part drilled, is this the return feed and is it a very fine hole, i.e. thickness of a wire strand, that may be blocked and can be unblocked. Have now bought a set of good circlip pliers and am about to pull the seal/piston and then clean everything out.
Thoughts please gents on the following
Am I right in what I'm thinking that the return hole blockage could cause this
If so what is the best method of unblocking and would a bigger hole be a problem
Do you need to glue the plastic reservoir to the master cylinder, if so what glue
If the piston and spring look OK would you just replace the seals, if they look OK just put in fresh fluid and bleed
(was going to change the pistons and seals but they look ok, minor corrosion marks and no leaks - better condition that my 06 suzuki 500 pistons)
I look forward to hearing from you, while I may not agree with all the responses they are valued and will be taken on board
