Is there a tutorial for changing the seals on the fork of a 1100 Gold Wing?
I would like to see some photos if possible.
Thanks, Dick
Other side of the pond
If they're leaking you could try pushing a strip of 35mm negative (film) down between the seal and fork tube to clean out whatever is causing it to leak. If that doesn't do it you'll have to change the seals.
The Honda service manual should have instructions on how to change the seals.
