1 - 9 of 9 Posts
aarrgghh. broke an easy out bit in the front of the oil cover on my 1100 gw. one of the 3
damm phillips stripped then the easy out broke off in the phillips head itself.. someone
suggested a diamond drill bit.. i have tried everything from titanium to carbon no go bad
weekend.. does anyone know where or how to remove this nitemare or suggest where
to find diamond bits..
thx gumby
Grind the head off the screw, remove the cover and then you can get the screw out.
hi and thx for the reply. how would i do this since it is almost flush to the engine itself?
and what would i use to do this with?
A Dremel tool is a very handy thing to have in your tool cabinet. You can get cutting and grinding wheels to do just about any small job. And they are not terribly expensive.
i do have a dremel tool but the easy out is hardened steel do you think i could get it
out with the dremel itself? maybe diamond bits. i have a new oil pump cover coming
thanks to jbhigg will try anything to remove this nitemare. have been at this for
2 days. have worked on goldwings before have rebuilt the intake system from my
delorean but this bike is a real project the previous owner knew nothing so the
bike lived in the moisture in the pnw.
o'well i will be better for this..
thx gumby
I think you could use a cutoff wheel in the dremel and cut the head off the screw, if you are going to replace the cover you can go ahead and sacrifice some of the cover to cut the screw off.
hi dave thought of that. but could i hurt any other parts behind the cover. the cover is no good anyway i just diden't want to hit an oil line.
You won't have to go all the way through the housing, just enough to cut the screw off. Nothing there to hurt anyway.
1 - 9 of 9 Posts
