1100 goldwing
512 Views 5 Replies 5 Participants Last post by  gumby
hi my front oil pump [the water pump seal holder] is fractured the part that has 2 phillips
and 3 plange bolts holding it in place the part behind the water pump. does anyone
have 1 of these for sale or? i replaced the water pump and tried to repair the holder
and guess what oil from the weep hole... crap...crap.. another weekend rebuild.
any help greately appreciated.
gumby
I think you mean 3 phillips head and 2 cap ( hex) screws .
PM sent
Did you find one? Let me know if you're still looking.
Scott
gumby, put your location in profile. may find someone close that has your part
mark:waving:
gumby what years your engine coz this cover changed slightly between 81 and 83 due the relocation of the neutral switch. 83 cover has neutral switch located in this front cover and earlier models the neutral switch is on side of engine.
attached pic shows insideboth casings
http://picasaweb.google.co.uk/tom4.brown/GlasgowingS81GL1100#5175177224151983074
she's a real beauty great job. question i'm having a helluva time trying to get my
water pump [the transmission cover side to seal] i am getting a little oil leakage the
weep hole. i noticed there is a slot where the small o-ring sits to prevent oil from seeping back thru to the water pump.every picture shows putting the small seal on
the pump housing 1st. i say into the back slot 1st.also should i put permatix sealer
around the o-rings [water and oil] this my 3rd go around pulling this project.
i have a 1983 gw 1100..
thx for your help..
