· Official "Cheeky Plonker"
I just bought me a good rear wheel and rotor, but the bearings weren't all they where cracked up to be and the non-drive side has no bearing retainer, I have a selection of rear wheels with retainers so I'm sure Ican get them out with a good tool to change out the bearings. I would prefer not to use the screwdriver method if I don't have to but if I have to I will.
So I'm asking the question, can I buy, borrow or rent one from someone on here so's I can get those suckers out. Or do you guys generally use the screwdriver method?
I don't know anyone who actually has the tool. I have used two punches with a breaker bar between them and in one case a single punch and a small ball peen hammer. Those retainers are not usually in there all that tight.
· Cyclebusters.com
find a pin spanner. works like a charm. they make adjustable ones. fix tons of other things as well
Thanks Cyclebuster, this little baby from Harbour Freight worked great, took that sucker right out, thanks again.
$6.99 Flat-Rate Shipping
  • Home|
  • Adjustable Pin Wrench
Double click on above image to view full picture
[/url]
.cboxPhoto {
float: left;
Pittsburgh - item#36554
5.0
(1)
Read 1 Review
Write a Review
Remove pins from any sized angle grinder with this pin wrench
Availability: In stock
$4.99
Only with coupon
Add item to cart to redeem coupon
Qty:
This item may be available at your local Harbor Freight Tools Store
Add to Wishlist
