Is there a diagram somewhere that shows where all the places that you can install a power plug are? I'm thinking that if I am going to order and install one, I might as well get two or three for future needs and do all my installs at once. I only want to use the plug and play options, so who knows where honda left open 12 volt plugs?
From what I know from my buddies 1800, there is one in the left faring pocket, and one in lid of the trunk....will need to drill holes for both, but they are plug and play.
Welcome to the forum McKenz1j
Thanks newday. @fishblock, I read about those as well, but I would really like a wiring diagram. I hate to just start taking things apart to see if there are wires underneath.
Pwhoever
But taking things apart is one of the best ways to learn how to work on your bike..... For the left pocket, it should be real easy to pop that out in no time.
There is the one under the left pocket, the one in the trunk lid is for the trunk light but could be used for a power port, it is hot all the time. I also found one that is not supposed to be there under the right side of the shelter.
