Is there a 12v power supply plug near the left hand frontglove box on a 05 1800 ???.. I want to charge up my mp3 player while mobile .. There is already a plug to play the mp3 player thru the radio..
Theres one just forward of the glove box, but you would normally use this to plug in the AUX wire into. There is another one in the big boot under the headlight adjuster switch as well. I didn't think you would be able to charge an mp3 player just by connecting it to as 12v supply?
Thanks Martin, I will check it out.. Ok on the direct 12 v supply , I do have an adapter to do the conversion from 12vdown...
cheers Bren
You can buy 12v stepdowns that will cover 9v, 6v, 3v, 1.5v for about $15. It's a handy thing to have on the Wing, you get all the usual adapters so you can run most toys. :waving:
Hi Joe, many thanks for your info. The adapter that I have sounds just like the one you describe, except we have to pay a lot more for it here in N.Z.
Cheers Bren :waving:
