1 - 20 of 22 Posts
i had 10w30 oil in my 1200 but i could hee my valves clicking a bit so i decided to put in 15w40 . now my valves click even more than before.
what should i use to get rid of the clicking noise?
Two possibilities I can think of. First check the rocker centering on it's shaft then check the shims. I don't think the type of oil will make any difference on valve noise.
If it has hydraulic lifters and they are dirty heavier oil is bad idea. Half bottle of ATF can clean them.
Before oil changes do what exavid says and verify the mechanics of the valves then check the hydraulics, especially if the bike has an unknown history.
I was just browsing the posts and ran across this
"Bad wiring causes anything from annoyances like static in stereo and intercom, to poor performance and fuel mileage up to severe engine cylinder damage from overheating. Before this was repaired, I measured over 500*F on exhaust headers, 240*F after repair, on idle. A burned connection on front of the start solenoid can cost your life when the cycle loses all electrical power on the highway. Youll swear on a stack of Monty Python videos that the "valve noise" in a GL1200 is really valve noise, the "valve rattle" in my engine disappeared once wiring was repaired."
Found it in this thread
http://goldwingfacts.com/forums/forum1/958.html
Maybe..............
I read farther along in that thread. If you skip to the last page, there are words of warning there. ( and the original post is 4 years old) I take it that we should take that thread with a grain of salt.
Oil change to 10w30, with 3 1/2 qts, then add a half qt of Marvel Mystery Oil.
Run for 500 miles - change back to 10w40 or something close.
That's my guess.
I also have a ticking, I don't know what it is. Sounds like fuel pump, but I can touch pump and tell its ticking at different rate. Due to road noise I can't tell where and I don't hear it in driveway. Best I an describe it, sorry
Discussion Starter · #9 ·
thanks for all the answers,the thing is i didnt hear or almost no ticking before i changed my oil to 15w40. guess ill just go back to 10w30.by the way handyman was that post talking about the spark plug wiring or the whole motorcycle wiring?
Texas Boy
I would say that in a moderate/cool climate like Quebec a 5w40 or 5w30 wouldn't be a bad choice either.
Discussion Starter · #11 ·
its actually pretty warm over here theses days,would 5w40 be a little too thin oil ?
Its still a 40w when it comes up to temp,its just a 5w when starting.When I ran the Rotella I let her warm up a little longer so the clutch had some warmer oil to work with.
Texas Boy
We may have different opinions of "warm". We've had over 60 days of temps over 100 (38 c). I run 5w40 year round, no problems. The 40 may actually be a little light at times but I haven't seen a problem from it.
Discussion Starter · #14 ·
ill take your word for it gary, ill go and buy some this afternoon and try it
thanks.
im tired of the clicking sound ...lol
What if he put some seafoam in it would that help to clean the valves and stop the clicking?
Discussion Starter · #16 ·
id love to use that stuff dusty, but seafoam is not available here in quebec canada
Texas Boy
I think just getting more oil into them will help. Seafoam would help too, but if you can't get it you can't get it.
1 - 20 of 22 Posts
