1200 keeping it running when first starting
592 Views 10 Replies 9 Participants Last post by  Bike...and Dennis
I just finished sync. the carbs the bike runs good after a little worm up, the problem is on start up i need to use the choke a little to keep it running Is that the norm. Thanks Tim
In a hurry with the spelling
1 - 11 of 11 Posts
Honda's are known to be very cold blooded.
Sounds normal to me.
My 1200 even when it is warm to hot outside typically needs the choke for a short time when first started.
Normal. if i start mine without choke, it will idle for 5 seconds at 300 rpm and then stall.. then i give it choke, start it and will hold 900 rpm, after one minute i can release the choke and wont stall but will idle very low, i have throttle lock so i just lock it at 1000 rpm till it warms up.
I just finished scoh. the carbs
Just curious what 'scoh.' is...
But anyway, I have to set the choke on my 1100 for about two minutes before it'll run properly.
Johnny Walker Red or Black? :dude:
I would say as well that this is normal..;)
Normal for mine too.
If it starts cold and keeps running without the choke is when there is a problem. Yours is normal.
G
Normal on mine.
Half choke for about 30 sec, then off choke.
Mine seldom needs the choke. But it's seldom cold here so maybe that's it.
1 - 11 of 11 Posts
