bike is not rideable way to much fuel all the time.the fuel prssure checked out ok. what do i test next?
There are some sensors that could be the problem, the first ones I would check is the PB (vacuum) sensors located on the frame in front of the air box. They have vacuum lines to them and the hoses could be broken, cracked or disconnected.
is this a problem that developed all of a sudden or has it gradually happened
have you recently changed belts,sparkplugs,checked wires or done any other work?
do you have the sei/ltd supplement to work with
pm sent
Discussion Starter · #9 ·
this problem started suddenly. yes i've checked all the things you can think of and found nothing. the ecu box is not blinking at all. not even when you turn the key on . does this sound right to you?
If you are not getting any codes, check the vacuum line going to the pressure regulator. If the diapragm has ruptured, you could be pulling fuel into the intake manifold that can't be compensated for.
