I'm working on a 1987 GL1200. When I turn the key on nothing happens. I checked the main fuse and it is good -- I have power to the fuse box. The first 2 fuses on the right side are powered up with the key off. I turn the key on and nothing powers up on the rest of the fuses. Is there a particular breaker or electronic box I should check out?
Thank you,
BMS
Thank you,
BMS
