I have a 1986 Aspencade.The po must have overtightened the rear axle.I say this cause when I changed the rear tire and reinstalled the assembly and tightened the axle nut the bolt holding the plastic cover to the rear rubbed on the wheel.I took things apart again and found the spacer/collar was crushed/mushroomed making it shorter.I ordered the correct part from Cheap Cycle Parts and it's too short.My part measures 104mm long and their part measures 98.5mm.Rick was very helpful and called Honda and all of their parts measure the same.What gives??Did someone sub a different year differential into my bike,how can I tell??
