Ok, after rebuilding my '85 Goldwing from a junk heap, then putting several thousand miles on it, I just ran into my first problem. All those miles were with just me on the bike, and it felt and handled fine. This morning I decided to take my 130 pound daughter for a ride. We didn't get very far till it was obvious something was wrong. Something was rubbing on the rear tire. Apparently my daughter and myself (220 pounds) were to much weight for it. It has standard spring rear shocks that I got from eBay in the stock length. This was an LTD model, but the air suspension system was completely shot, and the stock rear shocks were leaking badly, the fluid had already leaked out of them, and they would not hold air, even when I tried to put air in them with a pump. The boots were missing, and the lower part of the shocks were rusted and pitted, so I didn't even consider trying to rebuild them. And I still cannot afford air shocks. Does anyone know of any place where I can get some spring only shocks that are about 2" longer than stock?
I thought about trying to cut off part of the rear fender where it is rubbing on the tire, but even if that worked, I'm afraid it would not leave enough ground clearance to be safe in turns. Remember this started out as a scrap heap with a decent engine and not much else. I've already spent more on it than I really could afford, so $500 for a set of shocks is just not possible. Thanks for any help or suggestions.
