I am trying to re-wire the rear lights on my 1200. A PO installed the conversion kit that makes the two outer lights on the trunk a two bulb set up. One on each side would be a running light (3W) and the other was wired as a brake light (17.9W). The lenses are amber so these outer lights have to be connected as turn signals.
There is a 12V 17W festoon bulb in each side. Festoon bulbs resemble the old glass fuses but the glass bulges in the middle. Like a dome light bulb, but they are only 3W to 5W. These bulbs are also shorter than those available at the local auto parts store. These are 1.5 inches long.
There are two issues. One is that the socket or holder for the festoon bulbs is pretty hokey. It won't grip the bulbs. No spring action. I need to replace those.
The second is finding 17W or 18W bulbs in that style and length to fit the holder installed, new or existing.
What is used in a stock 1200 rear trunk turn signal for bulb and for holder?
Thank you all,
Lyle
Thank you all,
Lyle
