Haven't been fiddling but now the cruise lights (2) glow in normal running. They come on at startup as thery should - clear and bright and than dim to a low glow for the rest of the time. Cruise control works ok. I've checked all the wiring as far as I know but nothing seems to affect them. They carry on glowing. Any ideas please.
Les
Are you saying both light glow even with cruise switch off and not set?
If so verify if they go out when fuse #4 is pulled.
They must be getting a partial ground from somewhere. Either the light check relay or the cruise control unit. Maybe some moisture got into the connectors. Unplug the light check relay, on the right side of the frame in front off the coolant tank or the cruise unit itself may be easier to get to and see if the lights go off.
