by water pump cover, I assume you are talking about the large ring paper gasket. the OEM installation is dry.. but then the surfaces are also straight and new. I used a light coat of the spray-on gasket lacquer on the cover side and left it dry on the engine side.. it works fine.. I have also heard of members putting light coats of other sealers, however, do not use too much sealant(particularly the silicone) as it will glob up in the inside with the possibility of coming loose and clogging the oil screen... good luck.. Jim
