1 - 20 of 62 Posts
hi
im in the process of building a goldwing 1200 trike to meet UK regs im building it with no alterations to the bike frame so have to do itbolt on (so the bike can be put back as original just by removing bolts )
Discussion Starter #2
im using a ford sierra IRS (independant rear suspension) diff with home made uprights and wishbones
this is the start of the frame work that will hold the diff in place
as you can see from the pics ive already made the wishbones and the rear uprights
more pics to follow
Hmmmmm.....interesting !!!!:watching:
Looking good.
What are the grinding marks on the 3 (6) lower spars?
They also look like there is a slight bend in them?
tricky wrote:
Looking good.
Hi Tricky
i messed up i made the wishbones (spars) to a size and spec that's used for a build your own sports car
when i come to use them the bottom wishbones were too long so had to cut then take a small section out and turn a solid steel slug up in my lathe to a tight fit in the tubes and weld them back up
The picture your looking at it prior to them being welded just tacked on one side
That is looking good.
Will be watching this one.
you'll see from this next pic that the lower wishbones have been fully welded and a 4mm steel plate has been welded over the top of them for extra straight as well as a place to fit the coil-over shocks
Discussion Starter #10
Discussion Starter #12
tricky wrote:
Excellent
:thumbsup:will have more for you as i progress
just want to say Happy Thanksgiving to you all :july4thflag:
Discussion Starter #13
i turned some bushes to fit where the swing arm pivot bolts used to go
these bushes will enable me to secure the cage round the diff to the pivot points on the bike
theses tube will then be welded to the cage i hope your with me so far as im not real good with words lol
flat bar on this end so it will clear the drive shaft out put on the bike this will be drilled then bolted to through one of the bushes
one of the bushes in the frame
Discussion Starter #14
This picture shows you where i mounted the top fixings for the diff
i turend some buses to a tight fit where the shocks used to be mounted on the bike then i welded some more pipe to the bushes and to the top of the cage/diff
Another very interesting thread. Looking forward to seeing this one completed.
:claps:Very nice work **** . Thank You for sharing . I'll be keeping an eye on this thread .
Okay I see you have lot'sa fabricating skill and tool's care to elaborate on. Is this at your home or workplace makes me jelous and I have a fairly well stocked garage out back
Wilf
Also I love the light wieght approch. seems most trike kit's have massive amounts of steel back there. Not shure why perhaps they use it for balast?
Discussion Starter #19
Hi Wilf this is my home shop
its not very big i have some pics i will upload them later today for you .
and i'm not that clever without places such as this forum i wouldn't be able to do half what i do
1 - 20 of 62 Posts
