I've got the air shock apart, the oil seal is out, but I can't get to the case guide.
The 4 dimples on the upper housing won't allow it. Any suggestions?
Do you have a manual? If not, there is an electronic download here somewhere.
I do not think the shock comes totally apart per se. The service manual talks about seal removal, but that is accomplished by pumping up the shock.
The manual also discusses how to replace the ATF fluid and installation of the seals. There is also a oil seal driver. Section 12.
My Clymer says the rebuild should be done by the dealer.
Mr. Clymer should be tarred and feathered. Right after he's drawn and quartered. But before he's impregnated by space aliens.
Download the Honda Service Manual off the Reference Section here.
