1 - 9 of 9 Posts
I took the alternator out of my 1500 and am not sure how to remove the old brushes. Does anyone have a step by step on how to with pictures?
Thanks, Mark
I know my 88 was a cinch to do. Not really complicated. I believe that if you had a shop manual you'd be fine.
You really do need to follow along with a manual. Then this will make more sense.
Remove the 3 bolts along the side and separate the halfs
On the back cover half, remove the 5 nuts to separate.
Then you can see where the brushes are connected.
Another closeup.
New brushes next to old
Separate the cover plate, but do NOT disconnect the large copper wires to the stator.
I used a screwdriver handle to hold the brushes in place when soldering. You need to purchase a small electric soldering rod for best results.
You need the manual to make sure you allow enough length when placing the brushes. Then solder and cut flush. I use a straightened paper clip to hold the brushes in the holder. This clip can also go through a hold in the case already there, to keep things in place when you reassemble.
Those are the basic steps. It looks complicated, but it's really not. Just take your time and follow the book.
Thanks for the quick replies. I got the manual and also printed the good photos posted. I am going to try and get to it tonight if possible.
Thanks again, Mark
For anyone else who might be contemplating this job. Here are the pictures in the shop manual as referenced.
Here is page 2.
Page 3
Here is page 4
There is a page on bearing replacement and oil seal replacement that I skipped.
Here is final page.
1 - 9 of 9 Posts
