This was my first set of BS tires I usually run Dunlop E-3's and average about 19,000 miles before they need replaced, and there is tread left on them, but less than I like.
The Brigestones have right at 11,000 miles on them and are SHOT. I weigh 380 lbs so I run 42 psi in the rear and39 to 40 in the front. The rear has the rubber worn down to the wear bars and the front is cupped on both sides of center down to the wear bars with the center having good tread left.
Most of my riding with this set of tires has been on twisty curvy mountain roads ridden aggressively. I have ridden this waywith the E-3's with a lot better results than these BS.
I guess the question is have any of you gotten shorter life from Bridgestones than the E-3's?
As stated the bike is a 1994 1500
Thank You
Mike
Thank You
Mike
