Question: If I pull the vacuum advance line from the auto cutoff valve while shes running, she should die out right? I have been getting 30 mps and have already replace the cutoff valve inerds. I am getting leaking from the weep hole and I am not sure what i should be looking for. When i pulled the line from the valve it idled alittle rough not much, but she kept running. I would think this should cause it to die from lack of full, but i was wrong. I just think i should be getting better mpg than 29-32. Should i pull the plastic and spray the hoses with carb cleaner checking for leaks, or would this not affect it like that. I also have to choke her to get her to start up, even on warm days, after shes been sitting for a while. Any advice would be greatly appreciated. Thank You and God Bless.
