My friends 94se has had carb work done, po has moved the idle mixture screws from the factory position. Does anyone know the baseline, how many turns out from the seated position?
Jimmy
I thought is said three.
Old school general carb setting use to be 2.5 turns. Then after that the screws are to be turned to get the highest rpms at idle (adjusting idle screw to maintain idle). After that, then half turn righer.
